It is currently Tue Mar 31, 2015 12:34 am
 Post subject: Need help with C program
PostPosted: Thu Sep 19, 2013 10:24 am
writing a simple program for my programming 2 class, last week we had to write the a program with the same function but we passed by value, and this one needs to be by reference. The teacher did not help much. Here is my code:
#include <stdio.h>
float addTen(float* num, float* total);
float subtractSixteen(float* num, float * total);
float multiplyByEleven(float* num, float* total);
float divideByTwelve(float* num, float* total);
int main ()
int selection = 1;
float num, total;
printf("Please enter a number: ");
scanf("%f", &num);
while (selection >0 && selection <5)
printf("\nWhich of the following functions would you like?\n\n\tEnter 1 to add 10\n\tEnter 2 to subtract 16\n\tEnter 3 to multiply by 11\n\tEnter 4 to divide by 12\n\tEnter 0 to Exit\n\nSelection: ");
scanf("%i", &selection);
float* ptr_num=NULL;
ptr_num = &num;
float* ptr_total=NULL;
ptr_total= &total;
switch(selection)
case 1:
total = addTen(&num);
num = total;
break;
case 2:
total = subtractSixteen(&num);
num = total;
break;
case 3:
total = multiplyByEleven(&num);
num = total;
break;
case 4:
total = divideByTwelve(&num);
num = total;
break;
default:
break;
printf("\nYour total is: %.2f\n", total);
*num = total + 10;
float subtractSixteen(float* num, float* total)
*num = total - 16;
*num = total * 11;
*num = total / 12;
 Post subject: Re: Need help with C program
PostPosted: Thu Sep 19, 2013 12:31 pm
After looking at the code, I can point a few faults.
  • You don't need the ptr_num and ptr_total variables
  • Your calling your functions with one argument
  • There's a minor syntax error with the contents of those functions.
  • You're also not understanding the idea of pointers... maybe we should start with that first?
