It is currently Thu Jan 29, 2015 10:02 pm
 Post subject: Fill in text input fields in PDF file using VB/VC# code
PostPosted: Wed May 22, 2013 9:17 pm
Does anyone know if there is a way (besides buying a pre-compiled control kit from a company) to fill in text input fields in PDF files from Visual C# or VB.Net code? What I want to do is be able to extra data from our accounting system at work (which I can do already with VB using APIs built into the accounting system) and put the appropriate data into the appropriate fields in a PDF file that has editable text input fields.
Isn't the PDF/PDF-A spec pretty much universal now, so that an aftermarket pre-compiled add-in won't be required?
