It is currently Sun Apr 19, 2015 3:27 pm
 Post subject: VB6 Datagrid control
PostPosted: Wed Aug 17, 2005 5:07 pm
Anyone have a good site that details how to remove data from a datagrid control in VB6. I've searched a couple books and online, yet i still can't find anything on how to access an element in a row which the user has highlighted.- Thanks for the help
-Chris
PostPosted: Sun Aug 21, 2005 5:23 am
Team Member [Top 500]*
Hi and I am not sure I know exactly what you mean but assuming a dataGrid you would have:
DataSource=ADO Data Control's name
You would also set the AllowAddNew, AllowDelete, and AllowUpdate properties to true or false.
To delete a record in a DAO recordset , you use the Delete method and then you update the recordset. You would have a Delete button on your form, and maybe a few text boxes displaying the data. Something like this:
Private Sub Command1_Click()
Text1.Text=""
Text2.Text=""
dbrecordset.delete
End Sub
When the user clicks the Delete Button (Command1) the two text boxes Text1 and Text2 that display the data (for the current record) are cleared
and the record is deleted.
Is that what you mean?
Ron
PostPosted: Sun Aug 21, 2005 5:29 pm
I was looking for a way to go directly into the cell, although I’m starting to think there is no way to directly access the datagrid. I’m going to try to access the record set but other wise I’m thinking of changing it to a MSFlexgrid.
an example of what i was trying to do would be
number = grdDatagrid.index(4,4)
I know that’s not syntactically correct but its an example of what im trying to do.
