It is currently Tue Mar 31, 2015 7:40 pm
 Post subject: Java Help
PostPosted: Wed Jul 20, 2005 9:02 pm
I am working on a project I have been wanting to do for a little while. I know there are lots of applications out there, but I wanted to do it myself. I am wanting to create a alarm clock program in Java.
I am using JDK 1.05_03 and have reviewed the Calendar class I am using in this program. I am working slowing on this since I have a little less than one month off from work (without pay). I have it running as a console program first then want to modify it to work in JFrame.
I have displayed the entire instance of the Calendar I have created to check the values of the different variable, but the YEAR variable is not working properly for me. Here is the code I have.
   created:    7/19/2005
   Modified: 7/20/2005
import java.io.*;
import java.text.*;
import java.util.*;
class alarm {
   public static void main(String[] args)
      Calendar today = Calendar.getInstance();
      String outDate = "";
      String outTime = "";
      String period = "";
      int month = today.MONTH;
      int day = today.DAY_OF_MONTH;
      int year = today.YEAR;
      int dayPeriod = today.AM_PM;
      outDate = calcDate(month);
      switch(dayPeriod)
      case 0: period = "AM";
         break;
      case 1: period = "PM";
         break;
      outDate = outDate + " " + day;
      outDate = outDate + ", " + year;
      outTime = today.HOUR + ":" + today.MINUTE + ":";
      outTime = outTime + today.SECOND;
      outTime = outTime + " " + period;
      outDate = outDate;
      System.out.println("Today's Date: " + outDate);
      System.out.println("");
      System.out.println("Today's Time: " + outTime);
   public static String calcDate(int month)
      String  fullMonth = "";
      switch(month)
      case 0: fullMonth = "January";
         break;
      case 1: fullMonth = "Feburary";
         break;
      case 2: fullMonth = "March";
         break;
      case 3: fullMonth = "April";
         break;
      case 4: fullMonth = "May";
         break;
      case 5: fullMonth = "June";
         break;
      case 6: fullMonth = "July";
         break;
      case 7: fullMonth = "August";
         break;
      case 8: fullMonth = "September";
         break;
      case 9: fullMonth = "October";
         break;
      case 10: fullMonth = "November";
         break;
      case 11: fullMonth = "December";
         break;
      }; //end switch statement block.
      return fullMonth;
And here is the output I get so far.
Quote:
Today's Date: March 5, 1
Today's Time: 10:12:13
I am not looking for answers, but just ideas of what I am doing wrong or hint on where to go to find the solution. Thank you in advance for any and all help.
PostPosted: Wed Jul 20, 2005 9:55 pm
at a glance shouldnt it be MONTH not month
PostPosted: Thu Jul 21, 2005 11:13 am
I have the data from the calendar MONTH being stored in a variable named month. This is what I am passing to this method.
PostPosted: Thu Jul 21, 2005 12:23 pm
Million Club - 5 Plus*
You don't use Calendar.MONTH, which is static const int, you use today.get(Calendar.MONTH)
Also, try using DateFormat.
http://www.javaworld.com/javaworld/jw-1 ... dates.html
BTW, I have working code. ;)
PostPosted: Sat Jul 23, 2005 4:43 pm
But I thought since I made today an instance of the Calendar object, I could just access the MONTH constant like I did everything else. I will try it your way. I have the month working fine and all. I do not have the year coming through. If you display the entire object throught the command prompt you can see that YEAR=2005, which I want to store in the integer of my choosing.
PostPosted: Sat Jul 23, 2005 5:50 pm
public static final int MONTH = 2
public static final int DAY_OF_MONTH = 5
public static final int YEAR = 1
source: Java API contants
Those are why you are getting March 5, 1. You have to do the today.get(Calendar.MONTH), etc, to get what you want.
PostPosted: Sat Jul 23, 2005 8:30 pm
You are correct. Once I used .get(Calendar.MONTH) for whatever value I was trying to obtain I got the correct values to be stored in variables later.
I now having it working great and now on to the next phase. To implement this in JFrame, which is a simple process that I did a lot in the adv java programming course I just finished. I really like the absolute position available in java. It give a huge amont of control in the appearance of the GUI.
PostPosted: Wed Jul 27, 2005 7:19 pm
Bitchin' Fast 3D Z8000*
The instance of the Calendar object that you've instantiated stores the date information in non-public fields that can only be access via the get and set methods of the class. As you're probably already aware, this is called encapsulation - let's see who gives the most cogent answer about why it is done this way. ;)
The constant fields like MONTH, DAY and JANUARY are an enumeration so that your code is readable - cal.get(YEAR) or cal.set(JULY) instead of cal.get(4) or cal.get(1). The API states this pretty clearly:
static int MONTH
Field number for get and set indicating the month.
There is some good discussion in the API on how to use Calendar. Also, you should be using a DateFormat object to create the actual output.
http://java.sun.com/j2se/1.5.0/docs/api/
Date is in java.util
DateFormat is in java.text
PostPosted: Wed Jul 27, 2005 8:38 pm
Encapsulation is done to limit users access to variables and methods within a class and protecting these class defined objects. This method of access is done to protect the data from accidently being changed or modified and/or being directly access by any user of a program utilizing any class using encapsulation.
