It is currently Sun Mar 01, 2015 8:42 am
 Post subject: Problems compiling C++
PostPosted: Mon Jul 11, 2005 10:46 am
Well I've started C++. I've tried 2 different compilers, Borland C++BuilderX personal edition and DevC++ and I get the same error messages when I try and compile my code. They tell me that certain files are missing, I've tried 2 different books but neither one of them point to this particular problem so I'm stuck. Here is my code and the error message form my last attempt. Can some one explain to me how I can correct the problem?
//Conversion - convert temperature from Celsius degree to Fahrenheit degree
units:
Fahrenheit = Celsius * (212 - 32)/100 + 32
#include <cstidio>
#include <csdlib>
#include <iostream>
using namespace std;
int main(int nNumberofArgs[])
// enter the temperature in Celsius
int nCelsius;
cout << "Enter the temperature in Celsius:";
cin >>nCelsius;
// calculate conversion factor for Celsius
// to Fahrenheit
int nFactor;
nFactor = 212 - 32;
// use conversion factor to convert Cesius
// into Fahrenheit values
int nFahrenheit;
nFahrenheit = nFactor * nCelsius/100 + 32;
// output the results
cout << "Fahrenheit value is:";
cout << nFahrenheit;
cout << end1;
// wait until user is ready before terminating program
system("Pause");
return 0;
Errors;
4 c:\mydocu~1\c__com~1\tempco~1.cpp
cstidio: No such file or directory
5 c:\mydocu~1\c__com~1\tempco~1.cpp
csdlib: No such file or directory
Any ideas? :?
I've followed the books instructions to the letter and have rechecked my code severals times and can't see anything that I've done wrong. :cry:
PostPosted: Mon Jul 11, 2005 10:49 am
Are you compiling from a command line or from some sort of IDE/GUI?
PostPosted: Mon Jul 11, 2005 10:50 am
Nevermind. I think I see the problem.
Change:
#include <cstidio>
#include <csdlib>
#include <iostream>
To:
#include <cstidio.h>
#include <csdlib.h>
#include <iostream.h>
PostPosted: Mon Jul 11, 2005 11:09 am
I tried that, sorry but the same error messages come up.
I tried the "Console application" with the C++BuilderX IDE.
And the command line with the DevC++.
It makes no difference, that's why I'm a bit frustrated. I think that both authors neglected some basic instructions on setting up the compiler. :oops:
PostPosted: Mon Jul 11, 2005 12:11 pm
It looks like it can't find the include files. Is there a setting somewhere to tell it where to look?
PostPosted: Mon Jul 11, 2005 12:13 pm
Are those first three lines really three lines or just one line that wrapped?
PostPosted: Mon Jul 11, 2005 1:46 pm
Problem solved. I made a root directory in C: for those files. Then I copied and pasted the lesson onto another complier, for comparison purposes, and noticed that the font used in the book makes it difficult to tell the difference between a 1 and a l. I used the number when I should have used the letter. :P :oops:
Anyway thanks for the support and help. Very much appreciated, that ends about 5 days worth of frustation and banging my head against a wall. Fresh insight always helps, thanks again S3v3n11. :D
/ me goes off to do some more coding now that I've tasted success in C++. :D
PostPosted: Tue Jul 12, 2005 12:04 pm
Team Member Top 100
Team Member Top 100
Problem: csdlib should be cstdlib and cstidio should be cstdio
S3v3n11: That's a horrible suggestion, sorry. You're suggesting he use a less-supported, old, deprecated set of headers that pollute the global namespace instead of using the new headers. NEVER use the standard library headers that end with .h because they aren't even part of the standard library -- they are only provided by some compilers for compatibility with really old C++ code.
