It is currently Tue May 21, 2013 1:09 pm
 Post subject: HTML gurus, please help
PostPosted: Tue Aug 10, 2004 10:34 am
Hi HTML gurus,
I need some help here. Please let me know if this is doable, and why.
I want to automate some process. Basically, I would write an HTML file to have two frames, the upper frame containing another HTML/JavaScript file that I wrote, and the bottom frame would load a page from a 3rd party website.
I was hoping that after the bottom frame got loaded, the javascript in the top frame would be able to examine the contents of the bottom frame, and do different things accordingly.
var x = window.top.bottomframe.document.body.innerHTML;
// bottomframe is the name of the bottom frame
// parse x to do whatever
but everytime I run the javascript, it gives me an error saying something about access violation. Is it because the contents of the bottom frame belongs to a different domain and therefore my own code won't be able to access it? Is there a way to get around it? thanks
PostPosted: Tue Aug 10, 2004 10:46 am
Monkey Federation (Top 10)*
Can you post the link to the third party page that you are talking about?
PostPosted: Tue Aug 10, 2004 10:59 am
this was the link, but I cannot open it anymore.
http://gmailraffle.variantdata.com
basically it is a lotto for getting a gmail invite. I was hoping to writing a script to process it automatically, but apparently it did not work and I didn't get the invite.
now gmail don't matter anymore, and I am more interested in why it didnot work.
PostPosted: Tue Aug 10, 2004 1:52 pm
Bitchin' Fast 3D Z8000*
Something like this right (except you only want one window in the bottom frame, not 20)?
How funny is that.... MSN uses Java for their fantasy leagues... haha. :)
http://games.espn.go.com/content/ffl/20 ... ejavadraft
http://games.espn.go.com/content/fhl/20 ... ejavadraft
 Post subject: Re: HTML gurus, please help
PostPosted: Wed Aug 11, 2004 3:15 pm
emanresu wrote:
Hi HTML gurus,
I do not believe if I am correct that the window.top is required for your code. Try just bottomframe.document.body.innerHTML; since they are all contained within the same initial document and within frames of that document.
