It is currently Tue May 21, 2013 5:47 pm
 Post subject: Freeware Visual language
PostPosted: Wed May 25, 2005 8:28 am
Is there such a thing as a freeware program along the lines of Visual Basic or Visual C++?
I just want to make very basic (pardon the pun) programs that have buttons, edit boxes and drop down boxes.
Any help is appreciated.
 Post subject: Re: Freeware Visual language
PostPosted: Wed May 25, 2005 11:47 am
Bitchin' Fast 3D Z8000*
There are several. Try Java using the NetBeans IDE.
Here is a link to the NetBeans gui building tutuorial... http://www.netbeans.org/kb/41/form_getstart.html
PostPosted: Wed May 25, 2005 12:58 pm
Thanks for the link. :D
I've never programmed with Java before. When I think of Java I think of web applications. But this looks like what I was looking for. Thanks again.
PostPosted: Wed May 25, 2005 1:39 pm
When I tried installing it I got this message.
I tried using the "-is:javahome" option but I must be doing something wrong.
Any suggestions?
PostPosted: Wed May 25, 2005 6:34 pm
In the lab!
In the lab!
you need to install the sun java vm first if you haven't
PostPosted: Wed May 25, 2005 7:44 pm
I have Java's Runtime Environment installed. Downloaded Microsofts Virtual Machine but it says that it can only upgrade an existing copy. Does anybody have a link to a full install of MSJVM? (all the links I've tried are either dead links or links to upgrades)
PostPosted: Wed May 25, 2005 8:20 pm
Million Club - 5 Plus*
Have you installed the Java Development Kit from sun?
PostPosted: Thu May 26, 2005 5:26 am
My problem was I downloaded only Netbeans. I found a link to Netbeans with JDK and everything is working now.
Thanks.
PostPosted: Thu May 26, 2005 4:14 pm
Thanks.
Yeah, you have to have the JDK (aka Java SDK) installed to do any Java development work. Having a runtime is not enough.
PostPosted: Thu May 26, 2005 7:46 pm
Team Member Top 100
Team Member Top 100
http://bloodshed.net/
Download Dev-C++ and the MingW compiler, linker, and libs for free.
Or,
http://lab.msdn.microsoft.com/express/v ... fault.aspx
Beta 2 of VC++ EE is also free
PostPosted: Fri May 27, 2005 4:32 am
Thanks Kybo_Ren.
I'm more comfortable with C/C++ so this is exactly what I was looking for.
PostPosted: Fri May 27, 2005 6:44 pm
Team Member Top 100
Team Member Top 100
Sure, any time.
PostPosted: Fri May 27, 2005 7:06 pm
Or,
Does Dev-C++ have a graphics library?
PostPosted: Sat May 28, 2005 4:59 pm
Team Member Top 100
Team Member Top 100
Do you mean, "Does it come with OpenGL"?
IIRC it doesn't, but you can add it
PostPosted: Tue May 31, 2005 11:20 am
I was thinking more along the lines of a gtk, qt or something else. Have you done application development w/ OpenGL (normal apps, not game)? Is it any good for this?
PostPosted: Tue May 31, 2005 2:55 pm
http://www.icsharpcode.com/OpenSource/SD/Default.aspx
This is also a good .NET IDE...
PostPosted: Tue May 31, 2005 7:06 pm
Team Member Top 100
Team Member Top 100
I've done some, in the VC++ Beta 2005. It works pretty well.
From what I hear, Dev-C++ works fine with OpenGL and such
http://www.bloodshed.net/dev/ will tell you more, most likely
