It is currently Tue May 21, 2013 9:10 pm
 Post subject: PC Speaker Pulse
PostPosted: Mon Aug 02, 2004 11:45 am
I am working a simple OS, and have worked on the kernel and use GRUB as my bootloader. Now I want to program the PC speaker (not the sound card) to emit a POST-like series of beeps if something fails. Can anyone tell me why this code doesn't work?
int con_speaker(int freq)
{ if (freq <= 15)
  { freq = 131;
    //middle C (I think).
  int countdown = (1193180 / freq);
  int high = (int)(countdown / 256);
  int low = countdown - high;
  outportb(0x43, 0xB6);
  //send 'timer 2' a message to program countdown
  outportb(0x42, low);
  //send low.
  outportb(0x42, high);
  //send high.
  return 0;
int speaker_on()
{ int val = inportb(0x61);
  val |= 3;
  //Turn on bits 1 and 2
  outportb(0x61, val);
  //send it back;
  return 0;
int speaker_off()
  val &= 252;
  //Turn off bits 1 and 2
  //send it back;
  return 0;
If anyone want's to see outportb and inportb just ask, but I'm sure they work because the keyboard input/output is fine. The calling function does this (stripped version):
int test()
{ con_speaker(131);
  speaker_on();
  return 0;
Don't worry, the speaker gets turned off later.
PostPosted: Mon Aug 02, 2004 9:43 pm
Bitchin' Fast 3D Z8000*
Nice.... :) I'm going to be of very little help here. Just curious to see how this turns out.
First, you've probably pissed of the programming gods by not using K&R, so don't expect debugging to be rational... :)
I am curious....
why ( a / b ) in this case?
why caste to int? int / int == int
I really don't understand what con_speaker is suppose to do. Wht does con mean? At first glance, I thought you were setting up a high and low frequency range or something - "//I think 131 is middle C". After reading into it, I get the impression you're setting up a timer to run over a certain time period. Is that right?
PostPosted: Tue Aug 03, 2004 8:35 am
I am curious....
I am sorry if this seems like a stupid question, but what is K&R?
PostPosted: Tue Aug 03, 2004 12:42 pm
I am curious....
http://www.amazon.com/exec/obidos/tg/de ... 9?v=glance
A common programming style popularized by those two guys....
while (1) {
    i++;
//instead of
while (1)
   i++;
It tends to be shunned by C++ textbooks (why? I have no idea), but I've never seen a significant project or known of that doesn't use the K&R style either - all the free software uses K&R (linux, every bsd, etc), all the highest rated programmers at TC use it, the java programming sytle is similiar (minor change), and it is the prefered style of Stroustrup as well. Good company to keep.
The main benefit is that it saves vertical space on the screen (and in the books which often need the extra space even more... irony). You also know immediately from looking at the control structure line (ie the while in this case) whether you're dealing with a block or not. And in case you were wondering, that other style doesn't have a name - it isn't worthy!
*In all seriousness, it might have a name, but I'll be damned if I know anyone that uses that style that knows it. :)
PostPosted: Thu Aug 05, 2004 6:15 pm
"con" stood for "connect", but that wasn't really appropriate; what I really wanted to do was program timer two and use it to set the frequency on the speaker (but that's it, it doesn't really connect anything, more like initializes)... the cast to int? don't know about that one, just wanted to be safe (but you're right, totally unnecessary, since 'division' means 'integer division').
low and high is 'low order' and 'high order', because that's how you have to send it to the port (otherwise there is a much smaller range).
Yeah, my style is different (from both of them), but that's what happens when you learn by yourself; I might switch if it precludes me from getting a job.
speaker_on and speaker_off do exactly what they say...
The weird thing is, I tested it on an identical machine and the above code works...and I mean identical. Same BIOS, same BIOS settings, same everything, yet it doesn't play on my primary testing machine. Maybe some registers are getting trashed? Any insight would be helpful. (and yes, the speaker is enabled in the BIOS).
PostPosted: Fri Aug 06, 2004 11:04 am
Okay, I've decided to learn "Stroustrup Style" or "K&R for C++", since that is fairly close to my current style (but I absolutely refuse to rewrite anything unless someone else wants it). Does anyone have a good book/something for teaching this style (I found a short one on http://www.research.att.com/~bs/bs_faq2.html but I want to know if there is more to it)?
PostPosted: Sun Aug 08, 2004 9:44 pm
See the linux kernel docs..... they have a short howto on using K&R. As far as good book, see the resources section and the book by Stroustrup, while it doesn't teach K&R, is written entirely in this style and is the most recommended C++ book in existance. You can also refer to the Java Coding style at Sun, which is essentially K&R as well.
Any progress on your project?
 Post subject: Re: PC Speaker Pulse
PostPosted: Sun Aug 15, 2004 8:25 am
I'd rather be modding!
{ if (freq <= 15)
  { freq = 131;
  //send low.
  //send high.
  return 0;
int speaker_on()
  val |= 3;
  //send it back;
  return 0;
int speaker_off()
  val &= 252;
  //send it back;
  return 0;
int test()
{ con_speaker(131);
  speaker_on();
  return 0;
I r Python programmer (beware)
First, I think maybe try 400 instead of 131. Is 131 supposed to be the thue freq? as in 131 hetrz? That might be outside a PC speaker's range.
Forgive me if I am off the mark here. Also, can you ring the bell? Like ^g, just to confirm the speaker is working?
also " if (freq <= 15)" you should set to 20 (actually set it to 300 for a test). Most folks can't hear less than 20 and a PC speaker is not going to get near 20 in reality. You would just hear a "click" as it activates.
Also, what is the max on freq?
The above all assumes you are using hertz for freq.
Manta
PostPosted: Sun Aug 15, 2004 12:18 pm
Manta
Not only would a pc speaker not go down to 20 hertz, but most subwoofers can't either! I doubt a pc speaker can go below 100.
Good points.... so that's why JPL pays you the big bucks. :)
PostPosted: Sun Aug 15, 2004 1:13 pm
Hey Cplusplus have you seen my PM?
PostPosted: Sun Aug 15, 2004 2:07 pm
Heh - I am still waiting for a travel reimbursment from them :)
Manta
 Post subject: Thanks
PostPosted: Sat Aug 28, 2004 5:03 pm
Thaks for helping me. The speaker just 'clicked' before, as you (meaning the collective you) expected.
 Post subject: Re: Thanks
PostPosted: Sat Aug 28, 2004 5:29 pm
As I suspected. Did you get it fixed?
Manta
PostPosted: Sat Aug 28, 2004 5:31 pm
Yeah, I just upped the frequency (in Hertz), and now I can hear it.
PostPosted: Sat Aug 28, 2004 5:36 pm
Kewl
Manta
PostPosted: Fri Sep 17, 2004 6:08 pm
Team Member Top 100
Team Member Top 100
Middle A (A4) is 440 Hz.
You can find the frequency of another note with this formula:
Freq. = ((2^(1/12))^s) * 440 Hz
Where Freq. is the freqeuncy of the note, and s is the number of half steps up from A4 the note is.
This can be expressed in C as:
int s=-9;//back nine steps rfom a4 to middle c
unsigned int freq = 440 * pow(pow(2,(1/12)), s);
To go up or down an octave, multiply or divide by two (respectively).
