It is currently Thu May 23, 2013 9:02 am
 Post subject: Programming assignment
PostPosted: Sun Apr 24, 2005 12:33 pm
How would I change the deleteNode member function that when it is passed the value 0, it will delete all nodes with a value less than that?
Thanks.
#include <iostream>
using namespace std;
template <class T>
class LinkedList
   private:
      //  Declare a type for the list node
      class ListNode
         friend LinkedList<T>;
         T value;
         ListNode *next;
         ListNode(T value1, ListNode *next1 = NULL)
            value = value1;
            next = next1;
      ListNode *head;
   public:
      LinkedList()
         head = NULL;
      ~LinkedList();
      void appendNode(T);
      void insertNode(T);
      void deleteNode(T);
      void displayList();
//  appendNode appends a node containing the value
//  val passed as a parameter to the end of the list.
template<class T>
void LinkedList<T>::appendNode(T val)
   if(head == NULL)
      head = new ListNode(val);
   else
      //  nonempty list
      ListNode *nodePtr;  //  used to traverse the list
      nodePtr = head;
      //  traverse list to locate last node
      while (nodePtr ->next != NULL)
         nodePtr = nodePtr->next;
      //  ptr->next is NULL so nodePtr points to last node
      //  create new node and make it successor of what
      //  is now the last node
      nodePtr->next = new ListNode(val);
//  displayList shows the value
//  stored in each node of the linked list
//  pointed to by the head.
template<class T>
void LinkedList<T>::displayList()
   ListNode *nodePtr;
   nodePtr = head;
   while(nodePtr)
      cout<<nodePtr->value<<endl;
      nodePtr=nodePtr->next;
//  The insertNode function inserts a node with
//  val copied to its value member.
template<class T>
void LinkedList<T>::insertNode(T val)
   ListNode *nodePtr, *previousNodePtr;
   if (head == NULL  || head->value >= val)
      // new node goes at beginning
      head = new ListNode(val, head);
   else
      previousNodePtr = head;
      nodePtr = head->next;
      //  find the insertion point
      while(nodePtr != NULL && nodePtr->value < val)
         previousNodePtr = nodePtr;
      //  creates the new node and inserts it
      //  just before nodePtr
      previousNodePtr->next= new ListNode(val, nodePtr);
//  The deleteNode function searches for a node
//  with val as its value, the node, if found, is
//  delete from the list and from memory
template<class T>
void LinkedList<T>::deleteNode(T val)
   //  if the list is empty, do nothing
   if(!head)
      return;
   //  determine if the first node is the one to delete
   if(head->value < val)
      nodePtr = head;
      head = head->next;
      delete nodePtr;
   else
      //  initialize nodePtr to head of list
      nodePtr = head;
      //  skip all nodes whose value member is
      //  not equal to val
      while(nodePtr != NULL && nodePtr->value != val)
      //  Link the previous node to the node after
      //  nodePtr, then delete nodePtr
      if(nodePtr)
         previousNodePtr->next = nodePtr->next;
         delete nodePtr;
//  Destructor
//  This function deletes every node in the list
template<class T>
LinkedList<T>::~LinkedList()
   ListNode *nodePtr, *nextNodePtr;
   nodePtr = head;
   while(nodePtr != NULL)
      nextNodePtr = nodePtr->next;
      delete nodePtr;
      nodePtr = nextNodePtr;
PostPosted: Sun Apr 24, 2005 3:22 pm
#include <iostream>
class FloatList
   private:
      class ListNode
         friend FloatList;
         float value;
         ListNode *next;
         ListNode(float value1, ListNode *next1 = NULL)
            value = value1;
            next = next1;
      ListNode *head;
      void print(FloatList *);
   public:
      FloatList()
         head = NULL;
      ~FloatList();
      void appendNode(float);
      void insertNode(float);
      void deleteNode(float);
      void displayList()
      {print(class FloatList::head);};
//  num passed as a parameter to the end of the list.
void FloatList::appendNode(float num)
   if(head == NULL)
      head = new ListNode(num);
   else
      //  nonempty list
      nodePtr = head;
      nodePtr->next = new ListNode(num);
//  num copied to its value member.
void FloatList::insertNode(float num)
   if (head == NULL  || head->value >= num)
      head = new ListNode(num, head);
   else
      while(nodePtr != NULL && nodePtr->value < num)
      previousNodePtr->next= new ListNode(num, nodePtr);
//  with num as its value, the node, if found, is
void FloatList::deleteNode(float num)
   if(!head)
      return;
   if(head->value == num)
      nodePtr = head;
      head = head->next;
      delete nodePtr;
   else
      nodePtr = head;
      //  not equal to num
      while(nodePtr != NULL && nodePtr->value != num)
      if(nodePtr)
         delete nodePtr;
//  Destructor
FloatList::~FloatList()
   nodePtr = head;
      delete nodePtr;
//  Prints the contents of the node
FloatList::print(class FloatList::ListNode *head)
   if(nodePtr != NULL)
         cout<< nodePtr->value<<endl;
         displayList(nodePtr->next);
   return;
PostPosted: Sun Apr 24, 2005 3:32 pm
In the lab!
In the lab!
#include <iostream>
template <class T>
class LinkedList
   private:
      class ListNode
         T value;
         ListNode *next;
            value = value1;
            next = next1;
      ListNode *head;
     void showList(ListNode*);
   public:
      LinkedList()
         head = NULL;
      ~LinkedList();
      void appendNode(T);
      void insertNode(T);
      void deleteNode(T);
      void displayList();
template<class T>
void LinkedList<T>::showList(ListNode * nodePtr)
   //ListNode *nodePtr;
   //nodePtr = head;
   if(nodePtr != NULL)
      this->showList(nodePtr->next);
template<class T>
   if(head == NULL)
   else
      //  nonempty list
      nodePtr = head;
template<class T>
   this->showList(this->head);
template<class T>
   else
template<class T>
   if(!head)
      return;
      nodePtr = head;
      head = head->next;
      delete nodePtr;
   else
      nodePtr = head;
      //  not equal to val
      if(nodePtr)
         delete nodePtr;
//  Destructor
template<class T>
   nodePtr = head;
      delete nodePtr;
PostPosted: Sun Apr 24, 2005 3:43 pm
Final class code as of now. I need to figure out how to setup a delete member function correctly. It needs to accept a value and any node less than that it deletes.
#include <iostream>
template <class T>
class LinkedList
   private:
      class ListNode
         T value;
         ListNode *next;
            value = value1;
            next = next1;
      ListNode *head;
   public:
      LinkedList()
         head = NULL;
      ~LinkedList();
      void appendNode(T);
      void insertNode(T);
      void deleteNode(T);
      void displayList();
template<class T>
   //nodePtr = head;
   if(nodePtr != NULL)
template<class T>
   if(head == NULL)
   else
      //  nonempty list
      nodePtr = head;
template<class T>
template<class T>
   if (head == NULL  || head->value <= val)
   else
      while(nodePtr != NULL && nodePtr->value > val)
//  with val less than its value, the node, if found, is
template<class T>
   if(!head)
      return;
      nodePtr = head;
      head = head->next;
      delete nodePtr;
   else
      nodePtr = head;
      //  not equal to val
      while(nodePtr != NULL && nodePtr->value >= val)
      if(nodePtr)
         delete nodePtr;
//  Destructor
template<class T>
   nodePtr = head;
      delete nodePtr;
Code to look at
template<class T>
   if(!head)
      return;
      nodePtr = head;
      head = head->next;
      delete nodePtr;
   else
      nodePtr = head;
      //  not equal to val
      if(nodePtr)
         delete nodePtr;
PostPosted: Sun Apr 24, 2005 6:15 pm
In the lab!
In the lab!
#include <iostream>
template <class T>
class LinkedList
   private:
      class ListNode
         T value;
         ListNode *next;
            value = value1;
            next = next1;
      ListNode *head;
   public:
      LinkedList()
         head = NULL;
      ~LinkedList();
      void appendNode(T);
      void insertNode(T);
      void deleteNode(T);
      void displayList();
template<class T>
   //nodePtr = head;
   if(nodePtr != NULL)
template<class T>
   if(head == NULL)
   else
      //  nonempty list
      nodePtr = head;
template<class T>
template<class T>
   else
template<class T>
   ListNode *nodePtr, *previousNodePtr, *tempPtr;
   if(!head)
      return;
      nodePtr = head;
      head = head->next;
      delete nodePtr;
   else
      nodePtr = head;
      //  not equal to val
      if(nodePtr)
     if(val == 0) {
        //nodePtr = nodePtr->next;
              tempPtr = nodePtr;
           delete tempPtr;
     } else {
         delete nodePtr;
PostPosted: Sun Apr 24, 2005 6:18 pm
Working!!!
template<class T>
   if(!head)
      return;
      nodePtr = head;
      head = head->next;
      delete nodePtr;
   else
      nodePtr = head;
      //  not equal to val
      while(nodePtr)
         delete nodePtr;
       nodePtr=previousNodePtr->next;
PostPosted: Sun Apr 24, 2005 7:24 pm
#include <iostream>
template <class T>
class LinkedList
   private:
      class ListNode
         T value;
         ListNode *next;
            value = value1;
            next = next1;
      ListNode *head;
    int length(ListNode*);
   public:
      LinkedList()
         head = NULL;
      ~LinkedList();
     int numNodes()
     { return length(head);};
      void appendNode(T);
      void insertNode(T);
      void deleteNode(T);
      void displayList();
template<class T>
   ListNode *nodePtr;
   nodePtr = head;
   if(nodePtr != NULL)
template<class T>
   if(head == NULL)
   else
      //  nonempty list
      nodePtr = head;
template<class T>
template<class T>
   else
template<class T>
   if(!head)
      return;
      nodePtr = head;
      head = head->next;
      delete nodePtr;
   else
      nodePtr = head;
      //  not equal to val
      while(nodePtr)
         delete nodePtr;
//  Destructor
template<class T>
   nodePtr = head;
      delete nodePtr;
//  Counts the number of nodes in the list
template<class T>
int LinkedList::length(ListNode *nodePtr)
   if(nodePtr == NULL)
      return 0;
   else
      return 1 + length(nodePtr->next);
PostPosted: Sun Apr 24, 2005 8:20 pm
template<class T>
void LinkedList<T>::numNodes()
   float count = 0.0;
   ListNode *nodePtr;
   nodePtr=head;
      count++;
   divide = count;
   cout<<"   "<<count<<endl;
//  Totals up the values in the node
template<class T>
void LinkedList<T>::totalNodes()
   float add_up = 0;
   ListNode *nodePtr;
   nodePtr=head;
      add_up = add_up+ nodePtr->value;
   total=add_up;
//  Returns the average
template<class T>
float LinkedList<T>::avgNodes()
   totalNodes();
   numNodes();
   return total/divide;
PostPosted: Sun Apr 24, 2005 8:26 pm
#include <iostream>
#include <iomanip>
#include <fstream>
#include "LinkedList.h"
int main()
   ofstream ofile;
   ifstream infile;
   LinkedList<float> list;
   float val;
   //  Opens data files for input and output
   ofile.open("output.txt",ios::app);
   infile.open("LinkedList.txt",ios::in);
   infile>>val;
   list.appendNode(val);
   while(!infile.eof())
      infile>>val;
      list.insertNode(val);
   list.displayList();
   cout<<endl;
   float total_avg = list.avgNodes();
   cout<<endl<<total_avg<<endl;
   list.deleteNode(0);
   list.displayList();
   float positive_avg = list.avgNodes();
   cout<<endl<<positive_avg<<endl;
   infile.close();
   ofile.close();
   return 0;
