It is currently Sat Apr 25, 2015 4:55 am
 Post subject: Stupid Easy Java question
PostPosted: Sun Apr 17, 2005 5:48 pm
OK I'm just starting to learn Java and I'm stuck on probably a very simple question. The questions is:
Given integer variable i and a floating point variable f , write a statement that writes the values of i and f to standard output in the format:
i = value-of-i f = value-of-f
Hopefully this is enough info
Any help?
Thanks :D
 Post subject: Re: Stupid Easy Java question
PostPosted: Sun Apr 17, 2005 8:31 pm
Any help?
Thanks :D
Are you trying to send the values in the variables to the Console? If so, check out how to output to Console/Standard out. No one here will give you the answer, your best bet is to figure it out for yourself, write code, post code if you're having trouble and let us critique it - this way, you'll know what's going on and we don't get stuck doing your homework.
PostPosted: Sun Apr 17, 2005 9:05 pm
I'm getting errors when I put this:
System.out.println(" i = f = ");
PostPosted: Mon Apr 18, 2005 5:59 am
Two things:
1) That won't print the values of i and j, it will print "i=j=" since you encapsulated it the statement into a string.
2) Instead of using float, use double instead. The only difference between float and double is precision - float is 32-bits, double is 64-bits. Sun recommends using double instead of float and most compilers, IIRC, will enforce that.
BTW, post your code so we can see what it is you're trying to do exactly.
PostPosted: Tue Apr 19, 2005 6:56 pm
Well I got the answer...here it is
System.out.print("i="+i+" f="+f);
System.out.println();
thanks for the help
PostPosted: Thu Apr 21, 2005 11:37 pm
Bitchin' Fast 3D Z8000*
thanks for the help
Don't just 'I got the answer'... understand why that works.
You should be able to answer the following questions:
1. What is System? (A class, package, or something else?)
2. If a class, in what package is System located?
3. What is System.out, what args does it take, and what does it return?
4. What other methods besides println are available?
5. What types of variables are you passing to sout (for short), are any of them being caste? If so, how and why?
6. How could you have reduced the output from two lines to one line of code. And why would you want to? Why would you not want to?
7. Is the String literal mutable or immutable? How does the jvm handle String literals? Can you modify an immutable object?
8. How many different string concantenations does your main output line perform?
9. If it were in a loop iterating to say 1000, what should you do instead? And why? What is the relative cost in performance (both cpu and memory) of sout versus string concatenation versus string buffers.
And I won't even get started on unicode, locales, etc. Understanding is very (very, very, very) important - it is what seperates those who excel in the industry (and academia) from those who never get a job or just get by. It happens all the time - people who have been programming for 5+ years that take a serious spanking with the clue-by-four because they don't understand anything.
PostPosted: Fri Apr 22, 2005 5:55 am
thanks for the help
Good post. I should print this out and give it to other students I tutor. Knowing how to code and knowing what makes the code work is the difference between those who excel and those who don't. Fortunately enough, Reference books exists so questions like yours are easily answered as well. :P
PostPosted: Fri Apr 22, 2005 8:17 pm
Watch it - I copywrite all my posts. =)
