It is currently Tue May 21, 2013 9:17 pm
 Post subject: Sine/Cosine/Tangent Functions
PostPosted: Fri Aug 06, 2004 1:04 pm
Does anyone know how to do these (sin(x), cos(x), ln(x)) or other higher transcendals in C? Can't use any librarys, so just good old +-*/. Psuedocode is OK, as long as the math is there for me to see.
PostPosted: Fri Aug 06, 2004 1:14 pm
http://www.grc.nasa.gov/WWW/Wright/airplane/trig.html
That should do it.
What info do you have that you can work with? There are various methods of determining these values.
PostPosted: Fri Aug 06, 2004 1:41 pm
The math for approximating sine is below using the Taylor series. (x3 is x to the 3rd power).
sin x = x - x3/3! + x5/5! - x7/7! + ...
http://www.homeschoolmath.net/other_top ... ulator.php
x has to be in radians. Using just the first 4 terms should give you a value accurate to 7 decimal places. You may want to also write functions for raising a value to a power (Yes, this function already exists but its in the math library, same for factorial) as well as factorial.
double sin(double x) {
  return (x - ((x*x*x)/(3*2*1)) + ((x*x*x*x*x)/(5*4*3*2*1)) - ((x*x*x*x*x*x*x)/(7*6*5*4*3*2*1)));
The following would be a nasty quick and dirty way of approximating it using no math library functions.
PostPosted: Fri Aug 06, 2004 1:43 pm
I don't know for cosine, tanget, etc. You should be able to come up with a close approximation of them. In regards to the above formula, to get even closer you could do a recursive function im sure but I don't have time to code it out right now.
 Post subject: Sine
PostPosted: Mon Aug 16, 2004 11:05 am
Thank you so much DaBrain. That's what I wanted, the series, but I did not want a table. Now there are still a few more higher transcendals, like logb x, but I still don't know the series for that, or even if there is one.
