It is currently Wed Jun 19, 2013 9:39 pm
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Program I'm working on
PostPosted: Sun Apr 03, 2005 7:06 pm
No help needed at the moment
Class
#include <iostream>
#include <iomanip>
#include <math.h>
using namespace std;
#include <fstream>
class Fractions
   int numerator, denominator;
public:
   Fractions();
   void define_Fractions(int num, int denom);
   Fractions inverse(Fractions right);
   void print_Fractions();
   Fractions operator+(const Fractions &right);
   Fractions operator-(const Fractions &right);
   Fractions operator*(const Fractions &right);
   Fractions operator/(const Fractions &right);
   Fractions operator|(const Fractions &right);
   bool operator==(const Fractions &right);
   bool operator!=(const Fractions &right);
   bool operator>(const Fractions &right);
   bool operator>=(const Fractions &right);
   bool operator<(const Fractions &right);
   bool operator<=(const Fractions &right);
Fractions::Fractions()
   numerator = 1;
   denominator = 1;
void Fractions::define_Fractions(int num, int denom)
   numerator= num;
   denominator = denom;
void Fractions::print_Fractions()
   cout<< numerator <<"/" <<denominator;
//  Function the returns the inverse of a Fractions
Fractions Fractions::inverse(Fractions right)
   Fractions temp;
   numerator = temp.denominator;
   denominator = temp.numerator;
   numerator= temp.numerator;
   denominator = temp.denominator;
   return temp;
//  Overloaded addition operator for class Fractions
Fractions Fractions::operator+(const Fractions &right)
   Fractions temp;
   temp.numerator = (numerator * right.denominator) + (denominator * right.numerator);
   temp.denominator = denominator * right.denominator;
   return temp;
//  Overloaded subtraction operator for class Fractions
Fractions Fractions::operator-(const Fractions &right)
   Fractions temp;
   temp.numerator = (numerator * right.denominator) - (denominator * right.numerator);
   return temp;
//  Overloaded multiplication operator for class Fractions
Fractions Fractions::operator*(const Fractions &right)
   Fractions temp;
   temp.numerator = (numerator * right.denominator) * (denominator * right.numerator);
   return temp;
//  Overloaded division operator for class Fractions
Fractions Fractions::operator/(const Fractions &right)
   Fractions temp;
   temp.numerator = (numerator * right.denominator) / (denominator * right.numerator);
   return temp;
//  Overloaded inverse operator for class Fractions
Fractions Fractions::operator|(const Fractions &right)
   Fractions temp;
   return temp;
//  Overloaded equal to operator for class Fractions
bool Fractions::operator==(const Fractions &right)
   if(numerator == right.numerator && denominator == right.denominator)
      return true;
   else
      return false;
//  Overloaded doesn't equal to operator for class Fractions
bool Fractions::operator!=(const Fractions &right)
      return false;
   else
      return true;
//  Overloaded greater than operator for class Fractions
bool Fractions::operator>(const Fractions &right)
   if(numerator / denominator > right.numerator/right.denominator)
      return true;
   else
      return false;
//  Overloaded greater than or equal operator for class Fractions
bool Fractions::operator>=(const Fractions &right)
      return true;
   else if(numerator / denominator == right.numerator/right.denominator)
      return true;
   else
      return false;
//  Overloaded less than operator for class Fractions
bool Fractions::operator<(const Fractions &right)
   if(numerator / denominator < right.numerator/right.denominator)
      return true;
   else
      return false;
//  Overloaded less than or equal operator for class Fractions
bool Fractions::operator<=(const Fractions &right)
      return true;
      return true;
   else
      return false;
PostPosted: Sun Apr 03, 2005 8:49 pm
Main
#include <iostream>
#include <iomanip>
#include <fstream>
#include "Fractions.h"
int main()
   int num_1 = 1, denom_1 = 1, num_2 = 1, denom_2 = 1;
   int temp, temp_2, count = 0;
   char operation[2];
   bool value, print = false;
   Fractions left, right, together;
   ofstream outfile;
   ifstream infile;
   outfile.open("output.txt",ios::app);
   infile.open("Data5.txt",ios::in);
   cout<<"  Left                  Right"<<endl;
   cout<<"Operand  Operator      Operand   Result"<<endl;
   while(!infile.eof())
      infile >> operation[0];
      infile >> temp;
      infile >> temp_2;
      if( temp < 10)
         num_1 = temp;
         count = 1;
      else
         operation[1] = temp;
         count = 1;
         if (temp_2 =='-')
            count = 2;
      if(count = 0)
         temp_2 = num_1;
         infile >> denom_1;
         infile >> num_2;
         infile >>denom_2;
      else if(count =2)
         infile >> num_1;
         infile >> denom_1;
         infile >> num_2;
         infile >>denom_2;
      else
         temp_2 = denom_1;
         infile >> num_2;
         infile >>denom_2;
      left.define_Fractions(num_1, denom_1);
      right.define_Fractions(num_2, denom_2);
      if(operation[0] == '+')
         together = left + right;
      if(operation[0] == '-')
         together = left - right;
      if(operation[0] == '*')
         together = left * right;
      if(operation[0] == '/')
         together = left / right;
      if(operation[0] == '@')
         together = left | right;
      if(operation[0] == '<' && operation[1] == '=')
         value = left <= right;
         print = true;
      if(operation[0] == '<' && operation[1] != '=')
         value = left < right;
         print = true;
      if(operation[0] == '>' && operation[1] == '=')
         value = left >= right;
         print = true;
      if(operation[0] == '>' && operation[1] != '=')
         print = true;
      if(operation[0] == '=' && operation[1] == '=')
         value = left == right;
         print = true;
      if(operation[0] == '!' && operation[1] == '=')
         value = left !=right;
         print = true;
      left.print_Fractions();
      cout<<"         "<<operation[0];
      if(operation[1] > 10)
         cout<<operation[1];
      cout<<"            ";
      right.print_Fractions();
      cout<<"      ";
      if(print == false)
         together.print_Fractions();
      else
         cout<<value;
      cout<<endl;
      print = false;
      value = false;
      operation[0]=0;
      operation[1]=0;
      count = 0;
   return 0;
PostPosted: Sun Apr 03, 2005 9:11 pm
Input file
+ 1 2 3 4- 5 8 6 7* -7 9 4 5/ 6 7 2 3>= 1 2 3 4== 1 2 3 4< 1 2 3 4@ 1 2
PostPosted: Sun Apr 03, 2005 11:58 pm
What do you want? A cookie?
PostPosted: Mon Apr 04, 2005 3:16 pm
Actually I need help with reading the input. I post it there for people I know to see.
PostPosted: Mon Apr 04, 2005 6:06 pm
Another attempt at input
#include <iostream>
#include <iomanip>
#include <fstream>
#include <string>
int main()
   int temp = 0;
   char operation[2];
   operation[0]='0';
   operation[1]='0';
   ofstream outfile;
   ifstream infile;
      operation[0] = infile.get();
      temp = infile.get();
      if(temp == '=')
      if(operation[0]=='@')
         cout<<"first"<<endl;
         infile>>num_1;
         cout<<num_1<<endl;
         infile>>denom_1;
         cout<<denom_1<<endl;
      else
            cout<<"second"<<endl;
            infile>>num_1;
            cout<<num_1<<endl;
            infile>>denom_1;
            infile>>num_2;
            cout<<num_2<<endl;
            infile>>denom_2;
            cout<<denom_2<<endl;
         together = left.inverse();
         print = true;
         print = true;
         print = true;
         print = true;
         print = true;
         print = true;
      if(operation[1] == '=')
         cout<<operation[1];
      cout<<"            ";
      cout<<"      ";
      if(print == false)
      else
         cout<<value;
      cout<<endl;
      print = false;
      value = false;
      operation[0]='0';
      operation[1]='0';
      num_1 = 1;
      denom_1 = 1;
      num_2 = 1;
      denom_2 = 1;
      temp = 0;
   return 0;
PostPosted: Mon Apr 04, 2005 7:57 pm
Team Member Top 100
Team Member Top 100
Get a book on writing compilers and write a good parser.
Basically with fractions all you'll really need to do is tokenize the input (separate by operators) and use a bit of logic when you interpret the code. You can make a syntax tre if you want, and solve bottom-up if you really want to, but something like this probably doesn't require one.
PostPosted: Mon Apr 04, 2005 8:12 pm
I do not understand what you mean by that...
PostPosted: Mon Apr 04, 2005 8:14 pm
Bitchin' Fast 3D Z8000*
_alex911 wrote:
Input file
Maybe I'm being dense today, but I don't understand that input string. Is it prefix notation? It appears to be both pre and postfix! Can you write part of it out in English, that would help. =)
My current guess is...
1 2 means 1/2, right?
so...
1/2 + 3/4 - 5/8 * 6/7 - 7/9 / 4/5 or something....
PostPosted: Mon Apr 04, 2005 8:26 pm
1/2 + 3/4 solve answer
4/8 - 6/7 solve answer
etc
is 1 true or false in a bool?
I updated the code, i think it works now with the final main i have...
PostPosted: Mon Apr 04, 2005 8:34 pm
Output, think it is doing things right?
Left                  Right
second
1
2
3
4
1/2         +            3/4      10/8
second
5
8
6
7
5/8         -            6/7      -13/56
second
-7
9
4
5
-7/9         *            4/5      -28/45
second
6
7
2
3
6/7         /            2/3      18/14
second
1
2
3
4
1/2         >=            3/4      1
second
1
2
3
4
1/2         ==            3/4      0
second
1
2
3
4
1/2         <            3/4      0
first
1
2
1/2         @            1/1      2/1
Press any key to continue
PostPosted: Tue Apr 05, 2005 6:22 pm
How would I make the class function "print" write to file?
Thanks.
PostPosted: Tue Apr 05, 2005 7:39 pm
Team Member Top 100
Team Member Top 100
Thanks.
If I were in your situation, I'd take an ostream parameter in, with a default parameter of NULL. That way if they didn't specify an output stream, use std::cout, but if they did, you can use the specified output stream. Just use the ofstream class to write to a file and specify that as the stream.
This is where the power of classes and inheritance really starts to shine :)
PostPosted: Wed Apr 06, 2005 4:11 am
Kybo_Ren wrote:
Thanks.
I passed into the call of the print function (ostream &os) in the prototype and (outfile) and it worked.
PostPosted: Wed Apr 06, 2005 6:38 pm
Team Member Top 100
Team Member Top 100
What was I thinking? Just make the default parameter std::cout. You'll save yourself inefficient and ugly code.
PostPosted: Thu Apr 21, 2005 8:48 pm
In logic, it is...
true 1 on
false 0 off
In some programming languages, C or C++ for example...
true !0
false 0
I'm not sure if it is a requirement for you project, but it appears that your program doesn't attempt to reduce fractions which makes for some potential errors. For example, 1/2 > 2/4 should return 0! I'm not sure if your program handles correctly.
There are two approaches for addition (off the top of my head)...
1/2 + 3/4 = 4/8 + 6/8 = 10/8 then reduce to 5/4
or check whether one of the divisors can divide the other...
//freestyle programming - I haven't checked it - use at your own risk
int n1 = 1, d1 = 2, n2 = 3, d2 = 4;
int n3 = 0, d3 = 0;  //the answer
if (Math.max(d1,d2) % Math.min(d1,d2) == 0) {
    if (d1 > d2) {
        n3 = n1 + (n2 * (d1 / d2));
        d3 = d1;
    } else {  //if d2 >= d1
        n3 = n2 + (n1 * (d2 / d1));
        d3 = d2;
} else {
    d3 = (n1 * d2) + (n2 * d1);
I'll let someone else take a crack at one of the other ops.
PostPosted: Mon Apr 25, 2005 6:02 pm
Team Member Top 100
Team Member Top 100
In pure C++, it would be something like
struct Rational{
int num, den;
std::vector<int> Factors(const int &num)
     std::vector<int> factors;
     if(num == 0){
          return factors;
     for(int i = 2; i <= num; ++i)
          if(num% i == 0){
               factors.push_back(i);
     if(num < 0)
          factors.push_back(-1);
     return factors;
void ReduceFraction(Rational *frac)
     if(frac == NULL){
          return;
     if(frac->den == 0){
          return;//or throw an exception, whatever you want
     if(frac->num == 0){
          frac->den = 1;//not technically neccessary, but I like it
          return;
     std::vector<int> num_factors, den_factors;
     num_factors = Factors(frac->num);
     den_factors =  Factors(frac->den);
     if(num_factors.size() > 0 && den_factors.size() > 0){
          frac->num /= num_factors[0];
          frac->den /= den_factors[0];//could use num_factors, but w/e
          ReduceFraction(frac);//try to reduce more
     else{
     return;
PostPosted: Sun May 01, 2005 4:47 pm
I haven't tested it, but it looks like you may have an error in there Kybo....
Say I wanted to reduce 5/7's. After Factor is called...
num_factors = Factors(frac->num);  //contains {5}
den_factors =  Factors(frac->den);  //contains {7}
    //shouldn't num_factors[0] also have to equal den_factors[0]???
    frac->num /= num_factors[0];   // 5/5 = 1
    frac->den /= den_factors[0];     // 7/7 = 1
    ReduceFraction(frac);  //and now recursion w/ (1/1)
If I were doing it, I would have the Factors function return only prime factors, ie. 24 would return {2,2,2,3} not {2,3,4,6,8,12,24}.
If I were reducing 8 and 24, the factor call would return {2,2,2} and {2,2,2,3}. Then remove the intersection {2,2,2} from each list and multiply the remaining factors, respectively, resulting in 1/3.
The advantedge of not reducing to prime factors is that you may save some time by removing a large common factor quickly - assuming you approach the factors from large to small - but at the expensive of having to recompute the factors and doing multiple recursions.
PostPosted: Mon May 02, 2005 3:26 pm
Team Member Top 100
Team Member Top 100
Ah, good catch. I never tested it, I just wrote it in my post.
To keep the speed and accuracy, I'd test for primality of the number first, return immediately if prime, and then just return a single int from Factors and just use that instead of calculating all of the factors.
