The following is based on the
Haversine formula task on Rossetta Code. The
Haversine formula is used to find the distance between two points on a sphere using latitudes and longitudes. Let's start with the imperative code; Below are the C and Java versions of the code.
//C version
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#define R 6371
#define TO_RAD (3.1415926536 / 180)
double dist(double th1, double ph1, double th2, double ph2)
double dx, dy, dz;
ph1 -= ph2;
ph1 *= TO_RAD, th1 *= TO_RAD, th2 *= TO_RAD;
dz = sin(th1) - sin(th2);
dx = cos(ph1) * cos(th1) - cos(th2);
dy = sin(ph1) * cos(th1);
return asin(sqrt(dx * dx + dy * dy + dz * dz) / 2) * 2 * R;
int main()
double d = dist(36.12, -86.67, 33.94, -118.4);
/* Americans don't know kilometers */
printf("dist: %.1f km (%.1f mi.)\n", d, d / 1.609344);
return 0;
//Java
public class Haversine {
public static final double R = 6372.8; // In kilometers
public static double haversine(double lat1, double lon1, double lat2, double lon2) {
double dLat = Math.toRadians(lat2 - lat1);
double dLon = Math.toRadians(lon2 - lon1);
lat1 = Math.toRadians(lat1);
lat2 = Math.toRadians(lat2);
double a = Math.sin(dLat / 2) * Math.sin(dLat / 2) + Math.sin(dLon / 2) * Math.sin(dLon / 2) * Math.cos(lat1) * Math.cos(lat2);
double c = 2 * Math.asin(Math.sqrt(a));
return R * c;
public static void main(String[] args) {
System.out.println(haversine(36.12, -86.67, 33.94, -118.40));
If you haven't already, you should probably spend a minute looking at the formula on Wikipedia. It is pretty clear that the C and Java authors chose quite different approaches to implementing the details of the formula. If you removed the meta-info, many developers might not recognize that the functions perform the same calculation. However, I don't want to focus on the micro-details of the implementations. In both cases, the task is accomplished by a single function which converts individual parameters from degrees to radians. Both versions are pretty straight-forward implementations that I suspect a first year CS student could follow without much difficulty.
Let's take a look at the Haskell implementation.
--Haskell implementation
import Text.Printf
-- The haversine of an angle.
hsin t = let u = sin (t/2) in u*u
-- The distance between two points, given by latitude and longtitude, on a
-- circle. The points are specified in radians.
distRad radius (lat1, lng1) (lat2, lng2) =
let hlat = hsin (lat2 - lat1)
hlng = hsin (lng2 - lng1)
root = sqrt (hlat + cos lat1 * cos lat2 * hlng)
in 2 * radius * asin (min 1.0 root)
-- circle. The points are specified in degrees.
distDeg radius p1 p2 = distRad radius (deg2rad p1) (deg2rad p2)
where deg2rad (t, u) = (d2r t, d2r u)
d2r t = t * pi / 180
-- The approximate distance, in kilometers, between two points on Earth. The
-- latitude and longtitude are assumed to be in degrees.
earthDist = distDeg 6372.8
main = do
let bna = (36.12, -86.67)
lax = (33.94, -118.40)
dst = earthDist bna lax :: Double
printf "The distance between BNA and LAX is about %0.f km.\n" dst
This author has implemented the task using more of a functional programming style. Even if you're unable to follow the actual details, you can clearly see the task broken into several functions: hsin, distRad, distDeg and deg2rad. Personally, I think this approach to implementing the task is much clearer. The bottom-up design approach has resulted in smaller, more orthogonal, functions that can easily be reused in other programming tasks.
Below, I've translated both the C and Haskell versions to Common Lisp. My hope is that seeing the different approaches side-by-side will help demonstrate the differences. Please note that I've made some minor changes that reflect 'Lisp style'.
;;A fairly straight-forward C to CL translation
;;instead of dx*dx, I squared using the expt function
(let ((R 6371)
(TO_RAD (/ pi 180)))
(defun dist (th1 ph1 th2 ph2)
(setf ph1 (* (- ph1 ph2) TO_RAD)
th1 (* th1 TO_RAD)
th2 (* th2 TO_RAD))
(let ((dx (- (* (cos ph1) (cos th1)) (cos th2)))
(dy (* (sin ph1) (cos th1)))
(dz (- (sin th1) (sin th2))))
(* 2 R (asin (/ (sqrt (+ (expt dx 2) (expt dy 2) (expt dz 2))) 2))))))
;;A functional programming version of the program based on the Haskell code
(let ((earth-radius 6372.8)
(rad-conv (/ pi 180)))
(defun deg->rad (x) (* x rad-conv))
(defun haversine (x) (expt (sin (/ x 2)) 2))
(defun dist-rad (lat1 lng1 lat2 lng2)
(let* ((hlat (haversine (- lat2 lat1)))
(hlng (haversine (- lng2 lng1)))
(root (sqrt (+ hlat (* (cos lat1) (cos lat2) hlng)))))
(* 2 earth-radius (asin root))))
(defun dist-deg (lat1 lng1 lat2 lng2)
(apply #'dist-rad (mapcar #'deg->rad (list lat1 lng1 lat2 lng2)))))
CL-USER> (format t "The distance between BNA and LAX is about ~$ km.~%" (dist-deg 36.12 -86.67 33.94 -118.40))
The distance between BNA and LAX is about 2887.26 km.
Personally, I think that the functional programming approach is much better. Now, I do believe that the C version, for example, could be implemented in this style, but I don't think it would be as easy to follow the code. Perhaps someone else might want to try implementing it in this manner. I might spend some time tomorrow writing functional programming implementations in C# and Java using higher-order functions. Just for kicks, I might also implement the task in R.
For anyone wondering about the dist-deg function, I convert the args from degrees to radians using the mapcar functions, which returns a list, then use the apply function to call the dist-rad function. This is pretty straight-forward programming in Lisp, but I suspect it might not be something that a first year CS student would follow (outside of a top school).
