It is currently Wed Apr 01, 2015 5:53 am
 Post subject: Dynamic arrays
PostPosted: Thu Mar 10, 2005 8:05 pm
//  Joseph Kocurek
//  CMPS 1053 - Computer Science II
//  Program #3
//  This program dynamically creates two arrays
//  It then adds them together and then prints to screen/file.
#include <string>                              // String header file
#include <iostream>                              // Input Output stream header file
#include <fstream>
#include <string>
using namespace std;
void input();
void calculations(int * pointer_1, int * pointer_2, int * pointer_3, int biggest);
int main ()                                    // Main function
{                                          // Opens main function
   int *pointer_1, *pointer_2, *pointer_3;
   string entry_1, entry_2;
   int first, second, temp, biggest;
   ofstream outfile;
   outfile.open("output.txt",ios::app);
   // reads in the numbers to a string
   cout << "Enter the first number:  ";
   cin>>entry_1;
   first = entry_1.size();
   cout << "Enter the second number:  ";
   cin>>entry_2;
   second = entry_2.size();
   pointer_1 = new int[first];
   pointer_2 = new int[second];
   for(int n = 0; n < first; n++)
      pointer_1[first-1-n] = entry_1[n]-'0';
   for( n = 0; n < second; n++)
      pointer_2[second-1-n] = entry_2[n]-'0';
   if(first>second)
      biggest=first;
   else
      biggest=second;
   int carry=0;
   pointer_3 = new int[biggest];
   for(n = 0; n < biggest; n++)
      pointer_3[n] = carry + pointer_2[n] + pointer_1[n];
      if(pointer_3[n] > 9)
         carry=1;
      else
         carry=0;
   for(n = biggest-1; n>= 0; n--)
      cout<<pointer_3[n];
   delete [] pointer_1;
   delete [] pointer_2;
   delete [] pointer_3;
   outfile.close();
   return 0;
PostPosted: Thu Mar 10, 2005 9:07 pm
//  Joseph Kocurek
//  Program #3
#include <fstream>
#include <string>
void input(int &biggest,int first, int second,string entry_1,string entry_2, int * pointer_1, int * pointer_2);
void calculations(int carry,string entry_1,string entry_2,int * pointer_1, int * pointer_2, int * pointer_3, int biggest);
void print(int carry,string entry_1,string entry_2,int * pointer_1, int * pointer_2, int * pointer_3, int biggest);
   int carry=0;
   int first, second, biggest;
   ofstream outfile;
   input(biggest, first,  second, entry_1, entry_2,   pointer_1,   pointer_2);
   calculations( carry, entry_1, entry_2,  pointer_1,   pointer_2,   pointer_3,  biggest);
   print( carry, entry_1, entry_2, pointer_1,   pointer_2,   pointer_3,  biggest);
   outfile.close();
   return 0;
void calculations(int carry, string entry_1,string entry_2,int * pointer_1, int * pointer_2, int * pointer_3, int biggest)
   for(int n = 0; n < biggest; n++)
         carry=1;
      else
         carry=0;
void input(int &biggest, int first, int second,string entry_1,string entry_2, int * pointer_1, int * pointer_2)
   cin>>entry_1;
   cin>>entry_2;
   if(first>second)
      biggest=first;
   else
      biggest=second;
   for(int n = biggest-1; n>= 0; n--)
      cout<<pointer_3[n];
PostPosted: Thu Mar 10, 2005 9:23 pm
//  Joseph Kocurek
//  Program #3
#include <fstream>
#include <string>
void input(int &biggest,int &first, int &second,string entry_1,string entry_2, int * pointer_1, int * pointer_2);
void calculations(int first, int second,int &carry,string entry_1,string entry_2,int * pointer_1, int * pointer_2, int * pointer_3, int biggest);
   int carry=0;
   ofstream outfile;
   calculations(first, second, carry, entry_1, entry_2,  pointer_1,   pointer_2,   pointer_3,  biggest);
   outfile.close();
   return 0;
void calculations(int first, int second,int &carry, string entry_1,string entry_2,int * pointer_1, int * pointer_2, int * pointer_3, int biggest)
   if(first>second)
      biggest=first;
   else
      biggest=second;
         carry=1;
      else
         carry=0;
void input(int &biggest, int &first, int &second,string entry_1,string entry_2, int * pointer_1, int * pointer_2)
   cin>>entry_1;
   cin>>entry_2;
      cout<<pointer_3[n];
PostPosted: Thu Mar 10, 2005 9:27 pm
Team Member Top 100
Team Member Top 100
1.) Why all the posts? Just edit the first one.
2.) I assume you can't just use the vector container provided by the standard library? :lol:
3.) What is your question?
4.) Wouldn't it be better to create a dynamic array class (of course, in real-world programming you would just use std::vectors), and create two objects of those?
PostPosted: Thu Mar 10, 2005 9:58 pm
Team Member Top 100
Team Member Top 100
After talking on AIM we got it. Just posting the final result here:
//  Joseph Kocurek
//  Program #3
#include <fstream>
#include <string>
void input(int &biggest,int &first, int &second, string &entry_1, string &entry_2, int *& pointer_1, int *& pointer_2);
void calculations(int first, int second,int &carry,string entry_1,string entry_2,int * pointer_1, int * pointer_2, int *&pointer_3, int &biggest);
   int *pointer_1 = 0, *pointer_2 = 0, *pointer_3 = 0;
   int carry=0;
   ofstream outfile;
   std::cin.ignore(1000, '\n');
   std::cin.get();
   outfile.close();
   return 0;
void calculations(int first, int second,int &carry, string entry_1,string entry_2,int *pointer_1, int * pointer_2, int *&pointer_3, int &biggest)
   if(first>second)
      biggest=first;
   else
      biggest=second;
         carry=1;
      else
         carry=0;
void input(int &biggest, int &first, int &second, string &entry_1, string &entry_2, int *&pointer_1, int *&pointer_2)
   cin>>entry_1;
   cin>>entry_2;
      cout<<pointer_3[n];
