It is currently Fri Mar 27, 2015 1:05 am
 Post subject: C++ Question: Writing my own sort predicate
PostPosted: Sun Mar 06, 2005 8:46 pm
Hi, I need to sort my data, but because of the complication of it, I need to use a sorting predicate. I have an IDEA of how predicates work, but not much more....
My scenarios is:
struct str1 {
vector<string> phrase;
int numpos;
struct str2 {
vector<str1> Index;
str2 groupA;
I want to sort all the elements in groupA, based on the element "phrase", alphabetically.
any IDEA of what to do would be awesome,
Thanks!
PostPosted: Sun Mar 06, 2005 9:59 pm
Team Member Top 100
Team Member Top 100
You want to sort everything in groupA or all the elements in each one of groupA's member's phrase vector?
PostPosted: Mon Mar 07, 2005 2:09 pm
I want to sort GroupA.Index, but based on Phrase1 (alphabetically). Thanks!
PostPosted: Mon Mar 07, 2005 3:14 pm
Team Member Top 100
Team Member Top 100
Well, you're trying to sort based on a vector. Do you want to sort by the first string in the vector or something?
PostPosted: Mon Mar 07, 2005 5:47 pm
good point. actually it's a vector of words, so I'd like to first check the first word, then the second, etc.
If it's too complicated, then checking just the first word is probably enough...
Or maybe I can just merge all the words into one string beforehand??
Still no idea what to do,
Thanks..
PostPosted: Mon Mar 07, 2005 8:23 pm
Team Member Top 100
Team Member Top 100
Sure, you could merge all the words into one string. Wouldn't really do much though.
Can you explain the problem you are trying to solve instead of how to do this? It would probably be better if we knew the question.
PostPosted: Mon Mar 07, 2005 9:03 pm
PostPosted: Mon Mar 07, 2005 9:35 pm
Team Member Top 100
Team Member Top 100
Repost it in code tags so I can see the formatting, please.
PostPosted: Mon Mar 07, 2005 10:27 pm
okay, i fixed it.
Thanks again!
PostPosted: Tue Mar 08, 2005 4:28 pm
Team Member Top 100
Team Member Top 100
Well, first of all, you are most likely not going to get an EOF from stdin, so that input loop is pretty much infinite (if you move to a different stream it may change that, though).
Now, you since you are going to use std::sort for this, #include <algorithm>.
A predicate sort is simply a function that returns a bool and takes two parameters (the two things to compare). So, you want to make a function like:
bool rotation_pred_sort(const Rotation& T1, const Rotation& T2)
The actual comparison is simple enough:
    return T1.phrase[0] <= T2.phrase[0] ? 1 : 0;
Now, you want to actually do the sorting. This is how we do it:
std::sort(Strings.begin(), Strings.end(), rotation_pred_sort);
That's all, folks.
If you have any questions, feel free to keep posting them here.
PostPosted: Thu Mar 10, 2005 6:31 am
worked great! thank you!
