It is currently Fri Apr 17, 2015 11:50 pm
 Post subject: C++ question: working with a vector of stuctures ???
PostPosted: Tue Mar 01, 2005 9:03 pm
Hi, I'm assuming that I can use a vector of structures, but how do I add data onto it?
struct myStruct {
int x;
int y;
int main() {
myStruct hello; // creates a myStruct Structure called hello
// now I'd like to add an element onto the structure containing 5 for x, and 3 for y. Do I use hello.pushback()? Do I use hello.x.pushback(), or hello.pushback.x? How would I write that one line?
Thanks...
PostPosted: Tue Mar 01, 2005 9:35 pm
Team Member Top 100
Team Member Top 100
Probably the most straightforward way is:
#include <vector>
struct mystruct
   int x;
   int y;
int main()
   std::vector< mystruct > thevect;
   mystruct temp;
   temp.x = 5;
   temp.y = 3;
   thevect.push_back(temp);
   return 0;
PostPosted: Tue Mar 01, 2005 9:40 pm
Team Member Top 100
Team Member Top 100
If you don't mind using a class instead, here's a better way:
#include <vector>
class mystruct
public:
   mystruct(int a, int b);
   int x;
   int y;
mystruct::mystruct(int a, int b)
   x = a;
   y = b;
int main()
   thevect.push_back(mystruct::mystruct(5,3));
   return 0;
I mean, you ARE using C++ anyway.
PostPosted: Tue Mar 01, 2005 10:13 pm
I'm just beginning, haven't gotten to classes yet...
Though I know them in Java... whatever.
I think I see what you did. You created the entire structure as a temp, and then pushed it all back. Thanks!!
UPDATE: worked like a charm! Thanks again!
PostPosted: Wed Mar 02, 2005 2:59 pm
Team Member Top 100
Team Member Top 100
Sure, no problem.
PostPosted: Fri Mar 04, 2005 2:35 am
Bitchin' Fast 3D Z8000*
A struct and a class are basically the same thing. The only difference is that all of a struct's methods and fields are public by default.
