It is currently Sun Jan 25, 2015 8:39 pm
 Post subject: Using the google deskbar api
PostPosted: Mon Feb 28, 2005 4:58 pm
for those of you who do not know, the google deskbar is a small program which allows one to search google without opening the browser.
http://toolbar.google.com/deskbar/index.html
it so happens that google is distributing the api for this program so that .NET developers can make plugins. I found this interesting, and since i also have the google desktop search (http://desktop.google.com/) i wanted to add it as a plugin to the deskbar. there is only on problem. how do i load a different api into visual studio? when i click "New Project" my gut instinct is to click on "Blank Solution" but i am not sure what to do. All you get when you download the api is a dll which is used to make the plugin. i have never dealt with something like this before.
PostPosted: Mon Feb 28, 2005 5:45 pm
Team Member Top 100
Team Member Top 100
Do you get a .def file with it?
If not, then I'd go with the tried-and-true LoadModule(), GetProcAddress() solution.
PostPosted: Thu Mar 03, 2005 7:51 pm
i got a dll with it. i managed to import the reference, but in order to do so, i have to make a new project. the only problem is that i do not know which kind of project to make
PostPosted: Thu Mar 03, 2005 8:20 pm
Team Member Top 100
Team Member Top 100
Well, choose the project that suits your application. If you want to make a Windows app, choose the Windows application option, for a DLL choose the DLL option, etc.
PostPosted: Sat Mar 05, 2005 7:10 am
wait what is the dll option, i do not think that i have that
PostPosted: Sat Mar 05, 2005 12:15 pm
Team Member Top 100
Team Member Top 100
It's to make a DLL project.
Check this out for help:
http://deskbar.google.com/help/api/
PostPosted: Sat Mar 05, 2005 4:11 pm
yeah but in my new projects list i do not have that option
