It is currently Sun Apr 26, 2015 8:53 am
 Post subject: de-selecting radio buttons in VB.NET
PostPosted: Thu Feb 24, 2005 5:20 pm
Hey,
I've got three radio buttons on a form, along with a button that says "Cancel". Suppose the user selected one of the radio buttons and then clicked the cancel button. How would I code the cancel button's click event procedure so that it would de-select whatever radio button the user clicked on, leaving all three of them empty?
I did some digging on Google, and found lots of data on how to determine if a radiobutton had been selected, but can't figure out how to de-select them.
Does that make sense? Yhea, I suck at VB.NET, but I'm getting better. :wink:
 Post subject: Re: de-selecting radio buttons in VB.NET
PostPosted: Fri Feb 25, 2005 10:00 am
Treklink256 wrote:
Hey,
I am not sure how to do this in .NET version but in VB6 you can do this by naming the object and then its properties like this. rdo1.value = unchecked.
PostPosted: Sat Feb 26, 2005 4:44 pm
you have to set the checked funtion to false and example is RadioButton1.Checked = False
PostPosted: Sun Feb 27, 2005 2:40 pm
Well, I know THAAAT, I guess I should be more specific :roll:
I'm trying to write a loop that will do that to every radio button on the form.
Here's an example of what I'm trying to do (code below doesn't work, but I think you'll get the idea);
dim objControl as new control
for each objControl in form1
     if typeof controls.item is radiobutton then
          radiobutton.checked=false
     end if
next objControl
Or something like that.
Thanks for the suggestion, though!
PostPosted: Mon Feb 28, 2005 3:29 pm
why write a loop once there all unchecked then it wont execute agian. Do you want a buttion that does that if so just draw the buton on form double click it and in the routine just put the uncheck code in for each button.
PostPosted: Tue Mar 01, 2005 3:23 pm
Exactly. Why keep executing the loop once there's nothing left to uncheck? :P
Yhea, that's how I'm doing it for now. I've got quite a few radio buttons on this form, and I feel a little silly typing in 14 different unchecked = false commands - especially if there's a way I can write a loop to uncheck all 14 w/6 lines of code, it seems like that would be more efficient.
Not a huge deal, just seems odd.
NCC-1701-D Forever!
PostPosted: Mon Mar 07, 2005 10:38 am
I just finished a Semester of VB.net and one thing i learned about it is that if it seems to be a dumb solution its probably right. VB.net is kinda weird like that. Only way I could think a loop would work is that you have it cycle through all the objects on the form and check to see if its a radiobutton and if it is then set carry the name as a variable and use it to set it to false. probably would just be easier to do the uncheck un less you got 100+ radiobuttons.
