It is currently Sat Jan 24, 2015 8:57 pm
 Post subject: VS2010 & DX9 annoyances
PostPosted: Mon Nov 07, 2011 4:39 pm
Two things I have a problem with
I study a lot of example code from books and it just irritates me to have to convert the project and remove the 9 from dxerr.
1 Project Conversion
I am tired converting every project I open up in VS studio. All the example code is written in older versions of C++. Cant VS do the conversion on its on without showing the stupid wizard everytime? If not is there some 3rd party tool that will convert every project I want to look at without having to manually convert them one by one.
2 dxerr9
Every project I want to look at has dxerr9. Every time I have to go to the linker and the cpp file that has dxerr9 and delete the 9 for the project to compile. Is there some sort of tool that fix this for me with out me having to change it myself?
Thanks
 Post subject: Re: VS2010 & DX9 annoyances
PostPosted: Fri Nov 11, 2011 12:57 pm
You want to have control over the conversion. It isn't something that should be automagical. Wait till you have to migrate a huge solution. :)
Sounds like you should try to find newer examples of the code OR use an older environment.
