It is currently Tue Jan 27, 2015 12:28 am
 Post subject: Network Program Help
PostPosted: Sat Feb 19, 2005 5:21 pm
I am new to programming, but I am very network literite and work in the C# server rooms at HP. I would like to have a tiny program that does nothing but release the IP and then renew it without me having to type anything.
I would also love to have the functionality of viewing the current internet IP along with the LAN.
Any help would be great!
 Post subject: Re: Network Program Help
PostPosted: Sun Feb 20, 2005 2:48 am
Bitchin' Fast 3D Z8000*
How do you propose to do this? Brain waves or something? =)
PostPosted: Sun Feb 20, 2005 5:27 am
Could anyone here who has something legit to say help me out? The language could be Basic for all I care! I just need some help.
PostPosted: Sun Feb 20, 2005 9:13 am
I'd rather be modding!
Gadgets point was both a joke and a request.
You don't really give enough info about your vision - and the statement about "not having to type anything" makes it sound like you want it done by magic.
Can you atleast describe a senario?
Manta
PostPosted: Sun Feb 20, 2005 10:51 am
I was on edge this morning and did not take it like he ment it. Sorry about that...
Well...basically, when I am running a network, especially setting one up at a LAN party, the biggest problem I have is when a computer either has no NIC installed (stupid idiots..) or the IP is misconfigured.
The latter is much more frequent and I would like to have a program on a floppy that when run, will release & renew the LAN IP + give the internet IP for viewing. I would like to view the internet IP so I know that the computer is connected to the net.
This programs should be very simple, but since I have no programming experience other than ASP and HTML, my efforts would be fruitless.
Hope this explains a little bit better...
PostPosted: Sun Feb 20, 2005 11:26 am
In the lab!
In the lab!
1) what os we talking about... becuase the procedure would be different for win98 vs xp...
2) if we're talking 2k or xp... then open up a command prompt and take a look at ipconfig
USAGE:
    ipconfig [/? | /all | /renew [adapter] | /release [adapter] |
              /flushdns | /displaydns | /registerdns |
              /showclassid adapter |
              /setclassid adapter [classid] ]
where
    adapter         Connection name
                   (wildcard characters * and ? allowed, see examples)
    Options:
       /?           Display this help message
       /all         Display full configuration information.
       /release     Release the IP address for the specified adapter.
       /renew       Renew the IP address for the specified adapter.
       /flushdns    Purges the DNS Resolver cache.
       /registerdns Refreshes all DHCP leases and re-registers DNS names
       /displaydns  Display the contents of the DNS Resolver Cache.
       /showclassid Displays all the dhcp class IDs allowed for adapter.
       /setclassid  Modifies the dhcp class id.
The default is to display only the IP address, subnet mask and
default gateway for each adapter bound to TCP/IP.
For Release and Renew, if no adapter name is specified, then the IP address leases for all adapters bound to TCP/IP will be released or renewed.
For Setclassid, if no ClassId is specified, then the ClassId is removed.
Examples:
    > ipconfig                   ... Show information.
    > ipconfig /all              ... Show detailed information
    > ipconfig /renew            ... renew all adapters
    > ipconfig /renew EL*        ... renew any connection that has its
                                     name starting with EL
    > ipconfig /release *Con*    ... release all matching connections,
                                     eg. "Local Area Connection 1" or
                                         "Local Area Connection 2"
I mean it's no automated program but really is it that hard to type a few words?
PostPosted: Sun Feb 20, 2005 11:39 am
I know what to do, but this would be the building block program for soemthing more complex. I am currently planning a very simple program that will trace routed packets, run ipconfig release/renew, view internet IP, etc. This could all be done from a floppy!
The ipconfig thing I am trying to do now is the first of several features I plan to add in at a later time. I am putting my pinky toe in the water to test it and see how this all works out.
PostPosted: Sun Feb 20, 2005 3:35 pm
Maybe a batchfile will do it.
In python there is no "easy" way. Though its an interesting problem.
there may be a Java or C solution - not my current rhelm - sorry.
Manta
PostPosted: Sun Feb 20, 2005 8:06 pm
Your best bet is the batch file, just have it set so that it does ipconfig /renew everytime you reboot.
PostPosted: Sun Feb 20, 2005 8:09 pm
Why not just use a DHCP server? It's a lot easier and you can set your clients to automatically request an IP. From what your needs tell me, you need a DHCP server managing IP's than a program that will renew your IP's for you. Besides, you can't renew IP's unless you have a DHCP server, otherwise, the machine will assume that it's a static IP - BTW, that's true for all systems and not just windows.
PostPosted: Mon Feb 21, 2005 3:52 pm
I understand this and I have a router assigning IP addresses. Sometimes though, Windows does not want to renew correctly and therefore makes a fuss and keeps my friends from getting on the network.
This programs will delete the current IP and give it a new one, also showing me the internet IP so I know they are on the internet.
PostPosted: Mon Feb 21, 2005 5:58 pm
I'm sure that you can set the lease time on your router to be a short one. Also, if your router can assign the IP's, then let it do its job - writing a program that will do, in essence, what your router will do is a total waste of time - everyones time, including yours.
If you're really that adamant, just use a batch script and put it on your startup folder. Do something like:
ipconfig /renew
ipconfig /all > outputFile.txt
outputFile.txt
This way, when the machine is booted or rebooted, it gets an IP from the DHCP server, calls IPCONFIG and displays the result which is piped to a text file called outputFile.txt and then you open the outputFile.txt onto Windows using Notepad (since .txt files automatically associate itself with Notepad).
PostPosted: Mon Feb 21, 2005 10:53 pm
Manta
Maybe I should bold the smilie next time. ;)
PostPosted: Mon Feb 21, 2005 11:02 pm
A batch file is probably the easiest way to semi-automate the process you're describing, however, by the time you open the cmd window, type a: and myfile.bat, you really haven't saved any time over a simple ipconfig /renew_all have you?
Now if you were going to do something slightly more abitious like an auto-run cdrom that tries to diagnose / correct network problems and if everythignis fine then ties into a J2EE server or something which checks for and auto-magically downloads the latest patches and maps, I would say you might have something worth implementing.
I feel your pain though. Anyone who has setup a lan party knows this trouble you're describing. In the meantime, probably the best thing you can do is create some good documentation - help them help themselves.
PostPosted: Tue Feb 22, 2005 5:27 am
I finally gave in a created an online help thing non my web site. I will post this in the network section so that others may benefit also. Thanks again everyone!
http://www.lanpartyhome.com/networksetup.html
I especially had fun doing the Visio drawing.
PostPosted: Wed Feb 23, 2005 11:50 am
Team Member Top 100
Team Member Top 100
Look up sockets. You can try to connect to whatismyip.com and if it works, parse the output and spit out the IP address. For releasing/renewing the IP, I'm afraid that's driver-dependent (not sure), which means there's no good way of doing it.
PostPosted: Wed Feb 23, 2005 4:56 pm
I looked up the socket module in Python. You could do - but what a pain in the ass - you would have to be a deep network-socket-port pro.
A batch file on a floppy or piffed to a desktop icon would work :)
Manta
