It is currently Fri Apr 24, 2015 11:24 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: Issue With Font Display
PostPosted: Sat Jul 23, 2011 7:24 pm
I am having trouble creating font from an external class command outside my WinMain.cpp file. However it works if i send the external command in my "main" .cpp file. I was just wondering why it won't work in my Game.cpp file. Here are my codes:
WinMain.cpp: removed some irrelevant code.
m_pGame->MainDisplay(); initiates the external class there the external font commands are sent.
#include <windows.h>
#include <d3dx9.h>
#include "Game.h"
    HWND g_hWnd;
    LRESULT WINAPI WndProc(HWND hWnd, UINT uMsg, WPARAM wParam, LPARAM lParam);
    class CGame * m_pGame;
    class CDxDraw DxDraw;
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInst, LPSTR lpCmdLine, int nCmdShow)
{    char szAppClass[32];
    MSG uMsg;
    RECT rScreen;
    sprintf(szAppClass, "Client-%d", hInstance);
    WNDCLASSEX wc;
    wc.cbSize        = sizeof(WNDCLASSEX);
    wc.style         = (CS_HREDRAW | CS_VREDRAW | CS_OWNDC | CS_DBLCLKS);
    wc.lpfnWndProc   = WndProc;
    wc.cbClsExtra    = 0;
    wc.cbWndExtra    = 0;
    wc.hInstance     = hInstance;
    wc.hIcon         = LoadIcon(NULL, IDI_APPLICATION);
    wc.hCursor       = LoadCursor(NULL, IDC_ARROW);
    wc.hbrBackground = (HBRUSH)(COLOR_WINDOW+1);
    wc.lpszMenuName  = NULL;
    wc.lpszClassName = szAppClass;
    wc.hIconSm       = LoadIcon(NULL, IDI_APPLICATION);
    RegisterClassEx(&wc);
    DWORD dwStyle;
    g_hWnd = CreateWindow(szAppClass, "Helbreath 2 - A New Era", dwStyle, 0, 0, wx, wy, NULL, NULL, hInstance, NULL);
    if (!g_hWnd) {
        MessageBox(g_hWnd, "Create window pointer is corrupt.", "ERROR!", MB_OK);
        return 0;
    if (DxDraw.DX3DInit(wx, wy) != S_OK)
        MessageBox(g_hWnd, "Initialization error.", "ERROR!", MB_OK);
        return 0;
    m_pGame = new class CGame;
    ShowWindow(g_hWnd, nCmdShow);
    UpdateWindow(g_hWnd);
    char cTxt[32];
    short msX, msY, msZ;
    char cLB, cRB;
    HRESULT hr;
    while(GetMessage(&uMsg, NULL, 0, 0))
        DxDraw.BeginRender();
        //DxDraw.DisplayText(cTxt, 0, wy-20, wx, -1, 255, 255, 255, 255); // THIS COMMAND WORKS HERE!!! BUT NOT IN m_pGame->MainDisplay(); FOR SOME ODD REASON.....
        DxDraw.DisplayText("Beta Client", 10, wy-20, -1, -1, 255, 0, 200, 0);
        DxDraw.EndRender();
        TranslateMessage(&uMsg);
        DispatchMessage(&uMsg);
    return 0;
Game.cpp: class which contains the MainDisplay(); function and create font commands.
#include "Game.h"
extern int m_iMaxRes_X, m_iMaxRes_Y, wx, wy;
extern HWND g_hWnd;
CGame::CGame()
CGame::~CGame()
void CGame::MainDisplay()
    DrawGame.DisplayText("Beta Client", 10, 20, -1, -1, 255, 0, 200, 0); // DOESN'T SEEM TO WORK FOR SOME REASON....
Game.h: For definitions.
#include <stdio.h>
#include "DxDraw.h"
class CGame
public:
    CGame();
    virtual ~CGame();
    void MainDisplay();
    void DebugLog(char *cStr);
    class CDxDraw DrawGame;
    class CDxInput InputGame;
DxDraw.cpp: This calls all the d3d graphics functions (i.e. DisplayText(....) )
#include "DxDraw.h"
extern bool bFullScreen;
extern HWND g_hWnd;
CDxDraw::CDxDraw()
    g_pDirect3D = NULL;
    g_pD3DDevice = NULL;
    m_pFont = NULL;
CDxDraw::~CDxDraw()
{    int i;
    for (i = 0; i < DEF_MAXSPRITES; i++) m_pSprite[i] = NULL;
    m_pFont->Release();
    g_pD3DDevice->Release();
    g_pDirect3D->Release();
HRESULT CDxDraw::DX3DInit(DWORD iWidth, DWORD iHeight)
    if ((g_pDirect3D = Direct3DCreate9(D3D_SDK_VERSION)) == NULL){
        MessageBox(g_hWnd, "Direct3D create interface pointer is undefined.", "ERROR!", MB_OK);
        return 0;
    ZeroMemory(&d3dpp, sizeof(d3dpp));
    d3dpp.BackBufferWidth = iWidth;
    d3dpp.BackBufferHeight = iHeight;
    d3dpp.hDeviceWindow = g_hWnd;    // set the window to be used by Direct3D
    d3dpp.BackBufferFormat = D3DFMT_A8R8G8B8;    // set the back buffer format: D3DFMT_A16B16G16R16 = 64-bit (unavailable), D3DFMT_A8R8G8B8 = 32-bit with alpha channel
    if (bFullScreen) { // Fullscreen Mode
        d3dpp.SwapEffect = D3DSWAPEFFECT_FLIP;    // discard old frames
        d3dpp.BackBufferCount = 1;
        d3dpp.FullScreen_RefreshRateInHz = D3DPRESENT_RATE_DEFAULT;
        d3dpp.PresentationInterval = D3DPRESENT_INTERVAL_DEFAULT;
        d3dpp.Windowed = FALSE;    // program fullscreen
    }else { // Window Mode
        d3dpp.SwapEffect = D3DSWAPEFFECT_DISCARD;    // discard old frames
        d3dpp.Windowed = TRUE;    // program windowed
    HRESULT hRes;
    if(FAILED(hRes = g_pDirect3D->CreateDevice(D3DADAPTER_DEFAULT, D3DDEVTYPE_HAL, g_hWnd, D3DCREATE_MIXED_VERTEXPROCESSING, &d3dpp, &g_pD3DDevice))) return hRes;
    float Aspect = (float)d3dpp.BackBufferWidth / (float)d3dpp.BackBufferHeight;
    D3DXMATRIX matProjection;
    D3DXMatrixPerspectiveFovLH(&matProjection, D3DX_PI/4.0f, Aspect, 0.001f, 1000.0f);
    g_pD3DDevice->SetTransform(D3DTS_PROJECTION, &matProjection);
    g_pD3DDevice->SetRenderState(D3DRS_LIGHTING, FALSE);
    D3DXCreateFont(g_pD3DDevice, 13, 0, FW_BOLD, 0, FALSE, DEFAULT_CHARSET, OUT_DEFAULT_PRECIS, DEFAULT_QUALITY, DEFAULT_PITCH | FF_DONTCARE, TEXT("Tahoma"), &m_pFont);
    return S_OK;
void CDxDraw::BeginRender()
{    int i;
    if (g_pD3DDevice == NULL) return;
    // Clear the backbuffer to a black color
    g_pD3DDevice->Clear( 0, //number of rectangles to clear, 0 for all
    NULL, //rects to be cleared, NULL for entire buffer
    D3DCLEAR_TARGET|D3DCLEAR_ZBUFFER, //the buffers to clear
    D3DCOLOR_XRGB(255,255,255), //the Color to fill the buffer with
    1.0f, //depth for the z-buffer to clear
    0 //stencil buffer clear
    g_pD3DDevice->BeginScene();
    if (m_pSprite[i] != NULL) m_pSprite[i]->render(100);
void CDxDraw::EndRender()
   //Notify the device that we're finished rendering for this frame
   g_pD3DDevice->EndScene();
   //Show the results
   g_pD3DDevice->Present(NULL, //Source rectangle to display, NULL for all of it
                            NULL, //Destination rectangle, NULL to fill whole display
                            NULL, //Target window, if NULL uses device window set in CreateDevice
                            NULL  //Unused parameter, set it to NULL
void CDxDraw::DisplayText(char *pString, short sX, short sY, short sMaxW_X, short sMaxL_Y, short sA, short sR, short sG, short sB)
    // Create a rectangle to indicate where on the screen it should be drawn
    RECT rct;
    rct.left = sX;
    rct.top = sY;
    //Set default rectangle coordinates (hidden)
    m_pFont->DrawText(NULL, pString, -1, &rct, DT_CALCRECT | DT_WORDBREAK | DT_SINGLELINE, NULL);
    //Determine if align is required and set max rectangle rct.right(x)/rct.bottom(y) coordinates.
    if (sMaxW_X != -1) rct.right = rct.left+sMaxW_X;
    if (sMaxL_Y != -1) rct.bottom = rct.top+sMaxL_Y;
    //Draw text in set rectangle coordinates
    m_pFont->DrawText(NULL, pString, -1, &rct, DT_WORDBREAK | DT_SINGLELINE | DT_CENTER | DT_VCENTER, D3DCOLOR_ARGB(sA,sR,sG,sB)); //D3DCOLOR_ARGB(alpha,red,green,blue)
DxDraw.h: Incase the problem is here...
#include <d3dx9.h>
class CDxDraw
public:
    CDxDraw();
    virtual ~CDxDraw();
    LPDIRECT3D9 g_pDirect3D;
    LPDIRECT3DDEVICE9 g_pD3DDevice;
    D3DPRESENT_PARAMETERS d3dpp;
    LPD3DXFONT m_pFont;
    HRESULT DX3DInit(DWORD iWidth, DWORD iHeight);
    void BeginRender();
    void EndRender();
    void DisplayText(char *pString, short sX, short sY, short sMaxW_X, short sMaxL_Y, short sA, short sR, short sG, short sB);
    void bInit();
    void ResetDevice();
Thanks for your patience and help.
Sincerely, Kamal.
 Post subject: Re: Issue With Font Display
PostPosted: Mon Jul 25, 2011 1:58 pm
Don't double post. If you have additional information to add to your initial question, put it in the same thread.
