It is currently Mon Apr 27, 2015 1:26 am
 Post subject: Visual Basic for applications.
PostPosted: Wed Feb 16, 2005 5:52 pm
Can anyone suggest a good, easy to use book for a beginner to VB?
PostPosted: Thu Feb 17, 2005 6:59 am
The one i learned with in school was Mircosoft Visual Basic .NET Reloaded by Diane Zak I think its a good book and covers some nonVB.NET stuff like ASP and also teaches you about ADO.NET
PostPosted: Thu Feb 17, 2005 2:54 pm
I use "Programming in Visual Basic .NET" by Julia Case Bradley and Anita C Millspaugh.
The language changes too so get the most recent edition possible.
PostPosted: Thu Feb 17, 2005 7:54 pm
VB.NET and VBA are two very different entities. One is a robust fully object orientated business language, the second support automation and limited programming functions in business applications (and is used to write parts of the Office suite and other microsoft business apps).
VBA syntax is very similar to VB 5.0 and 6.0, but again VB 6.0 is separate entity as well.
Is it Visual Basic for Applications or VB 6.0 or VB.NET that you want a good book on?
I find the Learn in 24 Hours series excellent. Stay away from the complete references until you're familiar with the language, or are familiar with programming concepts.
As a beginner to program you will want a book that spends time on the basics of logic and structure as well as object orientated programming.
PostPosted: Sun Feb 20, 2005 5:24 pm
Soory it took so long to reply, but basically I wanted a book on Vb for applications, not VB or VB.net. Any suggestions?
