It is currently Fri Mar 06, 2015 7:05 am
 Post subject: VBExpress '05 Question
PostPosted: Sat Feb 12, 2005 8:45 am
I seem to having a rather annoying problem. Everytime i try to compile my large program (about 17 projects) i get an error saying that VBExpress cannot access the file because it is in use by another process (this happens on two of the projects). Does any one know how to fix this :?:
 Post subject: Re: VBExpress '05 Question
PostPosted: Sat Feb 12, 2005 10:11 am
Something has a hold of the projects. Try using a process viewer to see what process is holding onto the projects. Otherwise, try closing those two projects and then hit the compile button.
PostPosted: Sat Feb 12, 2005 10:18 am
Where do i get one?
I opened a new instance of VBExpress '05 and added the 2 projects in question to a blank solution and attempted to complie them both with no success.
PostPosted: Sat Feb 12, 2005 10:24 am
robert043 wrote:
Do you mean a process view like Task Manager on XP or something else?
I use a program called Process explorer.
http://www.sysinternals.com/ntw2k/freew ... cexp.shtml
You can view what Handle is holding onto the projects in question.
This is an odd problem, that and I've never messed with VBExpress '05.
PostPosted: Sat Feb 12, 2005 10:55 am
That (and another program called WhoLockMe) tells me that its the IDE locking the file.
How do i get to unlock the file and me be able to compile it again?
PostPosted: Sat Feb 12, 2005 10:59 am
Team Member Top 100
Team Member Top 100
Try closing it in all tabs, or opening all the files.
PostPosted: Sat Feb 12, 2005 12:06 pm
Neither works
PostPosted: Sat Feb 12, 2005 5:00 pm
I seem to have fixed this problem. How i dont know!
