It is currently Sun May 03, 2015 1:58 pm
 Post subject: Maximum length of a filename on Linux system runing Apache
PostPosted: Mon May 30, 2011 7:18 pm
What is the maximum length that a file name can be on a Linux system (32-bit) running Apache HTTP server? (Server version is 2.2.17)
Additionally, can you do things like this:
Filename: connection.guest.php
or-
Filename: connection.guest.inc
Or do you have to stick to a filename, a period, and then an extension only?
Someone told me it was 24 cahracters (not including the extension), but I'm not sure if that's even true, espeically on a linux system. What is the recommended max that I should use for a web server on Linux running Apache?
 Post subject: Re: Maximum length of a filename on Linx system runing Apach
PostPosted: Mon May 30, 2011 7:19 pm
I don't know about the max length, but pretty sure you can do whatever the fuck you want.
PostPosted: Mon May 30, 2011 7:21 pm
I'm sure pretty much anything will fly with Linux. I'm more or less concerned with potential issues with client computers viewing websites... I know obviously to try to use dashes not underscores, and no spaces in filenames, and that Linux file systems are case-sensitive (as in, use lower case), etc, etc.
Could a filename that excessively long or have an excessive number of periods in the filename affect a client computer's web browser or is that not even an issue?
 Post subject: Re: Maximum length of a filename on Linux system runing Apac
PostPosted: Wed Jun 01, 2011 3:06 pm
http://stackoverflow.com/questions/1547 ... 40#1547940
