It is currently Tue Jan 27, 2015 2:31 am
 Post subject: New to Visual C++
PostPosted: Tue Feb 08, 2005 5:55 pm
I'm new to Visual C++ and I need a little help with this. What I'm trying to do is use the GDI to create a program that will display the trigonometric sine and cosine functions, it will draw the x and y axes and allow me to draw sine and cosine using as many samples as I want. This is what I have in the OnDraw for the Sin command button: all I get is a straight line.
void CProject5View::OnDraw(CDC* pDC)
double PI = 3.1415926535;
int SamplesValue = static_cast<int>(300 - (m_Samples * PI));
pDC->MoveTo(60, 150);
pDC->LineTo(60, 300);
pDC->LineTo(575, 300);
pDC->MoveTo(60, 300);
pDC->LineTo(60, 450);
switch (m_Chart) {
case Sin:
pDC->MoveTo (300, SamplesValue);
pDC->LineTo (60, SamplesValue);
pDC->LineTo (270, SamplesValue);
pDC->LineTo (370, SamplesValue);
pDC->LineTo (470, SamplesValue);
PostPosted: Tue Feb 08, 2005 7:53 pm
Team Member Top 100
Team Member Top 100
Are you using MFC?
Use code tags BTW.
PostPosted: Wed Feb 09, 2005 2:49 am
Yes I am using MFC, sorry about that what are the code tags?
PostPosted: Thu Feb 10, 2005 9:18 pm
Post code in:
[code]
blocks like this.
[/code]
With BBCode on, it will look pretty.
PostPosted: Fri Feb 11, 2005 3:18 am
Thanks.
PostPosted: Fri Feb 18, 2005 5:52 am
No matter which number I enter I am getting a straight line, How do I calculate axes so when I enter another number it will start from the end of the previous line?
switch (m_Chart) {
case Sin:
