It is currently Mon Mar 30, 2015 5:58 am
 Post subject: I hate you, ORM...
PostPosted: Thu May 12, 2011 6:51 am
OK, so this is a project I'm wanting to get started. Let me give you a bit of backstory.
A few weeks ago, I switched out from a traditional DAL w/ POCO to using an ORM. To the unfamiliar, here are some terms:
DAL = Data Access Layer, you use this to perform data gathering/access functions. Whether you're talking to a database or a web service.
POCO = A play on POJO, or Plain Old Java Objects, it means Plain Old CLR Objects. I call them State Bags because they're .NET objects w/ no behavior, only state (data).
ORM = Object Relational Model, it's an object representation of your data store. So a table is an object, per se.
What pissed me off where the following.
1. In Entity Framework/OpenAccess ORM, there is a context object that you need to instantiate. This object maintains a scope with the datastore, so objects you retrieve from the datastore is, in essence, tied to the scope of the context. If you instantiate multiple contexts (e.g., in ASP.NET, the page life cycle drives object life and death), you can't pass an ORM object between separate contexts.
2. Most ORM objects cannot be serialized into XML, so good luck using remoting or any sort of a service tier where you need to serialize objects.
3. It's freakin' slow. Any schema change requires that you update the ORM meta-data. Not a big deal but it's still annoying.
There's already a project called Dapper.NET, but it doesn't handle relationships which is a huge bummer. Dapper also doesn't do query generation (IIRC) and it's merely an extension of IDBConnection. I don't want to fork the project from Github, plus I'm kinda bored and would like to work on a new'ish project. Ideally, this new data mapper should do the following:
1. Be able to use POCO types.
2. Should have a simple object model.
3. Should be intuitive.
4. Should handle relationships.
Coincidentally, I hate this about ORM's as well:
// To update an object
var myItem = context.Items.Where(x => x.Id == 1).SingleOrDefault();
if (myItem != null)
  myItem.ItemNumber = "1234567890"; // update it
context.SaveChanges();
What I hate about this is that the context holds onto the queried object. While it looks simple, it's not intuitive, ideally you should do this:
if (myItem != null)
context.Update(myItem);
Mainstream ORM's also handle multiple commands. They can create a command queue and execute them in FIFO order. However, mine won't do this. It's designed to be simple. If you want in on the project, let me know, I think it'll be a lot of fun plus it can be a MaxPC open source project! :D
We can create a "project charter" that lists what we hope to accomplish.
