It is currently Sun Apr 26, 2015 3:19 pm
 Post subject: Reading a set of int form standard input in c++?
PostPosted: Fri Feb 04, 2005 6:18 pm
I need to write a program that reads a set of integers from standard input and draws a bar chart to standard output using aterisks and spaces.
For example, if the user entered in the terminal
$ 1 2 3 4 0
the program must print:
I'm not getting the idea of using cin to get more than 1 integer, can any one help
thanks
PostPosted: Fri Feb 04, 2005 6:30 pm
Team Member Top 100
Team Member Top 100
cin >> obj1 >> obj2 >> obj3;
will assign the objects entered in stdin separated by spaces to obj1, obj2, and obj3.
Alternatively, you can do something like this (where <DELIM> is the delimiting character):
std::vector<int> ints;
std::string buf;
while(std::getline(std::cin, buf, '<DELIM>'))
    ints.push_back(std::atoi(buf.c_str()));
//now you have unlimited input of integers (only restrained by how much memory you have all in a vector
Though I suspect the second example is overkill :)
PostPosted: Fri Feb 04, 2005 6:46 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
you could do it wil batch.
 Post subject: Re: Reading a set of int form standard input in c++?
PostPosted: Sat Feb 05, 2005 4:38 pm
Bitchin' Fast 3D Z8000*
Do you know how many integers the user will enter before hand?
Also, are they entering them from the command prompt like so...
>myProgram.exe 1 4 3 9 4
This makes things much easier.
What is that suppose to mean?
PostPosted: Mon Feb 07, 2005 12:29 am
ouch, vertical bars ehh?
well, if this is for a class...then i doubt they (faculty) will let you use the ncurses library for this. This seems like an exercise in forloops?
$ 1 2 3 4 0
thanks
PostPosted: Mon Feb 07, 2005 12:30 am
ya, i couldn't figure it out either.
PostPosted: Mon Feb 07, 2005 8:20 am
Team Member Top 100
Team Member Top 100
He means you could write this program with a DOS script. Of course, since this seems like a homework assignment, that probably wouldn't be okay.
PostPosted: Mon Feb 07, 2005 8:23 am
oh.. a batch file. sure.. but that isn't in c++. i was a bit cornfused.
PostPosted: Mon Feb 07, 2005 9:00 pm
I would like to give a thanks to everyone for all your help and I have managed to get program working, look
#include <iostream.h>
using namespace std;
int main()
   int input;
   int size;
   int max = 0;
   const int MAX = 100;
   int values[MAX];
   for (size = 0; size < 100; size++)
      cin >> input;
      if (input == 0)
         break;
      else values[size] = input;
   // find the largest element in the array of values
   // values contains the values
   // size tells us how many values we have
   for(int i = 0; i < size; i ++)
      if(values[i] > max)
      max = values[i];
   // print the chart
   for(int row = max; row > 0; row--)
      for(int col = 0; col < size; col++)
         if(values[col] >= row)
            cout << "*";
         else
            cout << " ";
      cout << endl;
   return 0;
PostPosted: Mon Feb 07, 2005 9:10 pm
Team Member Top 100
Team Member Top 100
Don't use that header; it's deprecated.
Use <iostream>, not <iostream.h>.
If you have a teacher that tells you to use <iostreamh>, politely tell him he is wrong. If he insists upon it, rate him on ratemyprofessor.com
PostPosted: Mon Feb 07, 2005 11:16 pm
The program looks good.
PostPosted: Mon Feb 07, 2005 11:17 pm
LOL... and then forge an email from Bjarne scolding him. :D
