It is currently Sat Feb 28, 2015 5:15 pm
Post new topic Reply to topic  [ 19 posts ]
 Post subject: help with random code generator
PostPosted: Sun Oct 03, 2010 1:50 pm
I have been trying to create a mastermind game in c#. I have created a random color code generator, that never chooses purple. I can't see why, so any help would be appreciated.
using System;
using System.Collections.Generic;
using System.Text;
namespace Mastermind
    class Mastermind
        private static colors[] code, guess;
        private static bool correct;
        public static void Main(String[] arguments)
            //irrelevant commented out code
            for (int i = 0; i < 3; i++)
                CodeGen();
                System.Threading.Thread.Sleep(360);
                System.Console.WriteLine((int)code[0] + " " + (int)code[1] + " " + (int)code[2] + " " + (int)code[3]);
            System.Threading.Thread.Sleep(2000);
        private static void CodeGen()
            code = new colors[4];
            double onedivsix = 1.0 / 6.0, num;
            Random thing = new Random();
            for (int i = 0; i < 4; i++)
            top:
                num = thing.NextDouble();
                if (num < onedivsix)
                    if (Array.IndexOf(code, colors.Purple) != -1)
                        goto top;
                    else
                        code[i] = colors.Purple;
                else if (num < (2 * onedivsix))
                    if (Array.IndexOf(code, colors.Orange) != -1)
                        goto top;
                    else
                        code[i] = colors.Orange;
                else if (num < (3 * onedivsix))
                    if (Array.IndexOf(code, colors.White) != -1)
                        goto top;
                    else
                        code[i] = colors.White;
                else if (num < (4 * onedivsix))
                    if (Array.IndexOf(code, colors.Red) != -1)
                        goto top;
                    else
                        code[i] = colors.Red;
                else if (num < (5 * onedivsix))
                    if (Array.IndexOf(code, colors.Blue) != -1)
                        goto top;
                    else
                        code[i] = colors.Blue;
                else //if (num <= 1)
                    if (Array.IndexOf(code, colors.Yellow) != -1)
                        goto top;
                    else
                        code[i] = colors.Yellow;
        //several irrelevant, half finished methods
    enum colors
        Purple, Orange, White, Red, Blue, Yellow
 Post subject: Re: help with random code generator
PostPosted: Sun Oct 03, 2010 4:56 pm
Bitchin' Fast 3D Z8000*
It looks like you're making things quite a bit harder than they need to be...
CL-USER> (defvar colors (make-array 6 :initial-contents '(Purple Orange White Red Blue Yellow)))
COLORS
CL-USER> (defun random-color ()
           (aref colors (random 6)))
RANDOM-COLOR
CL-USER> (dotimes (i 8)
           (print (random-color)))
WHITE
YELLOW
ORANGE
WHITE
BLUE
BLUE
PURPLE
WHITE
Just curious - why do you need to create separate threads for this app?
PostPosted: Mon Oct 04, 2010 4:03 pm
Sorry, I'm a beginner, and my code probably isn't the best. I used the thread.sleep method to pause execution, because that's what I was taught (I know it's sloppy). Your code example doesn't make sense to me, the syntax doesn't seem to be c#.
PostPosted: Mon Oct 04, 2010 6:23 pm
Why are you pausing execution? You realize that the computer will block (ie wait) for user input when you ask for it, right?
It's not C#. I figured that it was close enough.
colors = make-array of length 6 with initial-contents {Purple Orange White Red Blue Yellow}  //global var
function random-color ()
  return colors[random(6)]
PostPosted: Mon Oct 04, 2010 9:24 pm
The current main function is temporary, I only need it to test the codegen function. I am pausing execution both as an extra (probably excessive) precaution while debugging, as quick repetition of the random function can result in it repeatedly returning the same number, and to give me time to read the output without having to fire up the command line. Part of the reason for the mess of code is that I don't want any repeats in the pattern. I changed the code to use a function of the Random class I must have missed back when I wrote the code.
the new codegen function:
            int num;
            top:
                //pick a int between 0 (inclusive) and 6 (exclusive)
                num = thing.Next(0,6);
                if (num == 0)
                    if (Array.IndexOf(code, colors.Purple) != -1)  // Possible mistake around Here?
                        goto top;                                  //
                    else
                else if (num == 1)
                        goto top;
                    else
                else if (num == 2)
                        goto top;
                    else
                else if (num == 3)
                        goto top;
                    else
                else if (num == 4)
                        goto top;
                    else
                else //if (num == 5)
                        goto top;
                    else
It still won't choose purple.
is the if block marked near the top of the function the culprit? I can't see anything wrong with it, but how can I be sure? I suppose it is worth mentioning that I am using Microsoft Visual C# Express.
EDIT: Slept on it, realized I should have used a switch statement. I'll work on it after school. Will also clean up the loop to get rid of the goto statements.
PostPosted: Tue Oct 05, 2010 4:25 pm
I figured it out.
Array.IndexOf(code, colors.Purple) == -1
always returns true. It turns out, when I initialize the colors array, each element is set to purple, not null. Therefore, until the array is filled, it will not set an element to purple (it turns out the type int, which enumerations are based on, is non-nullable) , at which point it exits the for loop. Working code below.
using System;
using System.Text;
    class Mastermind
            for (int i = 0; i < 8; i++)
                CodeGen();
            int num;
            for (int i = 0; i < 4;)
                switch (num)
                    case 0:
                        if (Array.IndexOf(code, colors.Purple) == -1)
                            i++;
                        break;
                    case 1:
                        if (Array.IndexOf(code, colors.Orange) == -1)
                            i++;
                        break;
                    case 2:
                        if (Array.IndexOf(code, colors.White) == -1)
                            i++;
                        break;
                    case 3:
                        if (Array.IndexOf(code, colors.Red) == -1)
                            i++;
                        break;
                    case 4:
                        if (Array.IndexOf(code, colors.Blue) == -1)
                            i++;
                        break;
                    case 5:
                        if (Array.IndexOf(code, colors.Yellow) == -1)
                            i++;
                        break;
    enum colors
        Purple = 1, Orange, White, Red, Blue, Yellow
PostPosted: Wed Oct 06, 2010 3:34 am
Pardon my French, but that is some fugly code... you wouldn't want me for a TA! =)
1) For starters, you should put the i++ in the for loop conditional (ie for (int i = 0; i < 4; i++) { case ... }
2) Why do you keep doing this?
3) "<snip> random function can result in it repeatedly returning the same number <snip>"
This should occur occasionally. Why do you think that your thread change the behavior of the random number generator?
4) "Part of the reason for the mess of code is that I don't want any repeats in the pattern."
Repeats in what pattern? Is codeGen supposed to return four different colors?
5) In terms of the design, you should create two methods: codeGen and colorGen. codeGen calls colorGen 4 times... or randomColor. See below.
CL-USER> (defvar colors (make-array 6 :initial-contents '(Purple Orange White Red Blue Yellow)))  ;;an array of colors
COLORS
           (aref colors (random 6)))      ;;returns a random color from the colors array
RANDOM-COLOR
CL-USER> (defun code-gen ()
      (let ((code (make-array 4)))    ;;create an array of length 4...
        (dotimes (i 4)                      ;;do 4 iterations...
          (setf (aref code i) (random-color)))   ;;fill it with random colors...
        code))  ;;return the array
CODE-GEN
CL-USER> (code-gen)                     ;;testing the code...
#(WHITE WHITE BLUE WHITE)
CL-USER> (code-gen)
#(RED RED YELLOW BLUE)
CL-USER> (code-gen)
#(WHITE YELLOW ORANGE WHITE)
CL-USER> (code-gen)
#(BLUE BLUE PURPLE WHITE)
CL-USER> (code-gen)
#(ORANGE WHITE ORANGE WHITE)
CL-USER> (code-gen)
#(ORANGE WHITE RED WHITE)
CL-USER> (code-gen)
#(WHITE BLUE RED ORANGE)
CL-USER>
PostPosted: Wed Oct 06, 2010 4:24 pm
This is a personal project, my school is to small to have a CS class. :(
Yes. codeGen is supposed to return 4 different colors, no repeats.
It will set the element in code[] and increment i only if the chosen color is not already in the code[]. Array.IndexOf returns -1 if the second augment is not found in the array, otherwise, it returns the index of the first occurrence.
I don't see how I can without either
a) putting back in the goto statements, or
b) altering the behavior of the code.
Yes, occasionally a random function should return the previous result again, but if you call the function to quickly, it will return the same value until you give it a break. quick, repeated calls could result in it returning
6,6,6,6,6,6,6...
That code is just me being excessively cautious while debugging. It will be removed.
Couldn't hurt. At this point I'm just happy it works, although I am open to suggestions for improving it. Thanks for your help!
PostPosted: Thu Oct 07, 2010 2:44 pm
Gotcha. That clears up a lot of the confusion with some of your code. I'm going to suggest that you take a different, and again, simpler approach.
pseudo-code...
function code-gen
code = array of length 4
colors = list of possible colors
color = null, just a temp variable
for i from 0 to 3
  color = random color from the colors list
  code[i] = color
  remove color from the colors list
return code
;;Actual working code...
(defun code-gen ()
   (colors '(Purple Orange White Red Blue Yellow))
   (color nil))
    (dotimes (i 4)
      (setf color (nth (random (length colors)) colors))
      (setf (aref code i) color)
      (setf colors (remove color colors)))
    code))
;;some test runs...
CL-USER> (code-gen)
#(WHITE ORANGE YELLOW BLUE)
CL-USER> (code-gen)
#(RED WHITE ORANGE YELLOW)
CL-USER> (code-gen)
#(WHITE BLUE PURPLE RED)
CL-USER> (code-gen)
#(ORANGE YELLOW BLUE WHITE)
CL-USER>
Normally, I'd write the code in a more lispy style, but I think this probably translates better for you.
PostPosted: Thu Oct 07, 2010 2:53 pm
6,6,6,6,6,6,6...
No. If the RNG that you're calling is implemented correctly, it will return a random value regardless of how little or much time passes between calls.
Are you confusing initially seeding a RNG with the current time for repeated calls to the RNG? In several languages, it is common to seed the RNG with the current time, however, you only seed the RNG with the time once, then make calls to something like a next() function.
PostPosted: Wed Oct 13, 2010 2:24 am
How is the project coming along? What's next?
I wouldn't creating a Common Lisp port along side your C# version... =)
PostPosted: Wed Oct 13, 2010 1:55 pm
Haha I may try this in Perl. Can't imagine it would be too hard :P
PostPosted: Thu Oct 14, 2010 12:22 am
Don't worry... I have faith in you finding a way! =P
PostPosted: Mon Oct 18, 2010 10:51 am
Did we lose freak720? This was an interesting thread for a little while there.
Dwood15, if you know how to play Mastermind, why don't you go ahead and define another module of code and we'll get the ball rolling again. Any part will be fine, we'll just work on it in a bottom-up style for now.
PostPosted: Wed Oct 27, 2010 7:49 pm
Come on Dwood, don't let this thread die... Let's do this app!
PostPosted: Thu Oct 28, 2010 4:50 am
I have never played mastermind... basic premise of the game? I'd be willing to take part if we can all agree that C# is the way to go :)
PostPosted: Mon Nov 01, 2010 1:30 am
I don't really know the premise. I glanced at the Wikipedia article a while back when I was busy, but I didn't have time to read or understand much about it. It's a board game, and you try and break the opponents code (or something).
When Dwood made the Perl comment, I started thinking that it would be interesting to see how a few different language implementations compared to each other. To my eye, the game appears to be about the right level of complexity for this sort of thing: not trivial, not too complex, not huge, not a full-time job. I suggested the bottom-up approach so that people could start suggesting functionality without having to invest a lot of time in the design up front. I was also curious to see how the languages might adapt to changes using a bottom-up approach.
Anyways, I'm pretty booked until December. If someone hasn't suggested another bit of code to write by that time, I might post something to get the ball rolling again.
PostPosted: Thu Nov 04, 2010 5:43 am
Interesting. I will have to look into it. I might try to do something with XNA. It would be a good excuse to work on a game on the framework.
PostPosted: Thu Sep 08, 2011 3:37 pm
private Color[] colors = { Color.Red, Color.Yellow, Color.Blue, Color.Green,
Color.DarkOrange, Color.Black, Color.Gray, Color.Purple };
Random rnd = new Random();
for (int x = 0; x < litir.Length; x++)
pictureBox1.BackColor = colors[rnd.Next(x)];
pictureBox2.BackColor = colors[rnd.Next(x)];
pictureBox3.BackColor = colors[rnd.Next(x)];
pictureBox4.BackColor = colors[rnd.Next(x)];
row1[0] = pictureBox1;
row1[1] = pictureBox2;
row1[2] = pictureBox3;
row1[3] = pictureBox4;
and pictureBox5-44 are filled with the guesses
and so on ... ;)
in this version the same color can come up more than once. That´s more fun.
