It is currently Sat Apr 25, 2015 4:11 am
 Post subject: App or method to run several browsers on a single machine
PostPosted: Fri Oct 01, 2010 1:35 pm
Is there a way that I can run several versions of the same browser on a machine for development purposes (I do web design and like to check compatability with various browsers, and browser versions, but don't want to have to have a room full of computers to do it. I figure, a computer running XP, one with 7, and a Mac should be fine enough, and maybe a Linux computer).
Any way that I can do this. LIke I want to test a site with FF1.x, 2.x and 3.x, and then IE6, IE7, and IE8 as well as Safari version 3 and later. What's the best way to go about this?? I'm aware of the idea of dual-booting but that will only accomplish so much for me.... I need a better way.
I don't mind runnning the newer s tuff (Safari 5, FF3 and IE8 on all the same Windows 7 machine) and then maybe IE6, FF2 and Safari 3 or 4 on a WinXP machine, etc etc...
I'm not so worried about HTML support as I am CSS support across browsers and browser-versions. I'm trying to develop sites that are compatible with older browsers (because I realize my target market may not have the latest technology and some may still be using IE6 and/or FF2.x or something even older.)
 Post subject: Re: App or method to run several browsers on a single machin
PostPosted: Sun Oct 03, 2010 4:43 pm
Bitchin' Fast 3D Z8000*
Virtualization is your friend! Check out VirtualBox and VMWare.
PostPosted: Mon Oct 04, 2010 5:04 am
Look up IE Collection.
You could run various portable versions of Firefox.
VMs seems overkill for only browsers.
PostPosted: Mon Oct 04, 2010 12:46 pm
well, i do programming as well, so I figured at least with that, I could test my software in various environments as well. If it was ONLY for browsing purposes, I'd say forget the VMs, but I do like the idea of being able to run older apps / testing apps in older/different OSes. I only really need to go back to IE6 and probably FF2.x. Those are my two main concerns, since they make up a good percentage of browsers being used. I'd also like to test on Chrome and Safari (for those die-hard Mac users who don't use FF on the Mac).
PostPosted: Mon Oct 04, 2010 3:41 pm
Be sure to test on Opera as well... =)
PostPosted: Tue Oct 05, 2010 6:53 am
Fuck Opera. Nobody cares about it. :)
PostPosted: Wed Oct 06, 2010 3:42 am
Good point. If you're app doesn't work in one of the best, and most standards compliant browser available, then I shouldn't be using your app. You're saving me time! =)
PostPosted: Wed Oct 06, 2010 6:59 am
^^ Yours is a not widely shared opinion. I mean, even Apple's browser has more users! :)
While I was mostly joking that nobody cares about it the truth is hardly anybody does. If you are developing a web app I would test with IE and FF and Chrome. If it works in those, it will likely work in Safari and Opera.
http://gs.statcounter.com/
