It is currently Sun Mar 29, 2015 6:29 pm
 Post subject: insparsing HTML and PHP code together - security issues?
PostPosted: Thu Sep 09, 2010 12:25 pm
Is there a security issue with maxing HTML code insode of a PHP script, like this...
<?php
<html>
<body>
<p>Hello!</p>
echo "<p>How are you</p>";
<p>I am doing fine.</p>
</body>
</html>
versus something like this...
<?php
echo "<html>\n";
echo "<body>\n";
echo "<p>How are you</p>\n";
echo "<p>I am doing fine.</p>\n";
echo "</body>\n";
echo "</html>\n";
Is the first or second method more secure, or does it not matter? Plus, which method would "execute" faster or get interpreted faster by the PHP parser?
 Post subject: Re: insparsing HTML and PHP code together - security issues?
PostPosted: Fri Sep 10, 2010 9:17 am
Other than the syntax you are using being wrong... no. It is how most is done.
<html>
<body>
<p>Hello!</p>
<?php
</body>
</html>
PostPosted: Fri Sep 10, 2010 9:43 am
As Crash said, no, both are just fine. With regards to performance: if there were a difference, it would be negligible (near zero).
However, I would argue that the first method is more readable than the second. Why bother encapsulating HTML inside an echo statement when all you're doing is outputting HTML to begin with? Just print the HTML and don't worry about echo - only echo if you need to do something like:
<p>I am doing fine, but when I checked my weight this morning, I weighed <?php echo $weight; ?> lbs. </p>
Strive for readability, performance is negligible.
PostPosted: Fri Sep 10, 2010 10:31 am
Not to mention you have to type more with option 2 :)
