It is currently Thu May 07, 2015 1:43 am
 Post subject: Skin a form? [C#/VB.NET 2010]
PostPosted: Wed Aug 04, 2010 10:19 am
I want to make a form-skinning library, using extension methods:
this.Skin(new BlackSkin());
and I've got the skinning part figured out - but if the user draws graphics using the Paint event, the code would break, because it would be along the lines of:
f.Paint += (object sender, PaintEventArgs e) => {
     // code in here to draw custom background, rounded edges, shadows, etc.
Which would overwrite anything the user drew. Plus, it would flicker.
I've made Aero-style forms for XP by having any Aero forms inherit Vista_Form but I can't really change what the form inherits from, can I?
Any ideas?
PostPosted: Wed Aug 04, 2010 12:44 pm
Million Club - 5 Plus*
Are you using WinForms or WPF? (I'm guessing WinForms)
PostPosted: Wed Aug 04, 2010 12:57 pm
WinForms, of course :) I hate WPF. Plus, this is to skin Form objects, so I can't switch.
