It is currently Sun Feb 01, 2015 11:12 am
 Post subject: PHP Debugging
PostPosted: Sat Jul 17, 2010 2:46 pm
I'm curious if anyone can give some specific instructions on how to get a good IDE setup to debug PHP applications. I am tired of needing to use an echo for debugging - I'd much rater be able to set breakpoints from the IDE - step through code etc, much like I do when working with .NET
I know there is a paid program out there, VS PHP or something, but I'd rather get it done with something free such as Eclipse or Netbeans, whichever works best.
I've tried folloiwing some examples on some websites, but they never end up working correctly.
And in case it matters, I'm running Windows 7
PostPosted: Sun Jul 18, 2010 8:29 am
Stop using PHP...
There isn't a good way to debug it that I have seen. I gave up caring about PHP though. It made me angry in so many ways, because of just that. Tutorials not working correctly.
What tuts have you tried?
PostPosted: Sun Jul 18, 2010 2:32 pm
CrashTECH wrote:
Stop using PHP...
I don't have direct links to the tutorials - but I have tried many, even some from Netbeans own website, as well as Zend's website.
And I would take your advice to leave PHP - however I have some projects I'm working on and my clients are using PHP.
I guess I'll just have to stick with the echo statements.
PostPosted: Wed Jul 28, 2010 6:56 pm
Yeah, I'm doing PHP for school. Extremely frustrating when debugging compared to a language like Java. For example, if I misspell a variable name, I'll get an error in Java, however, nothing happens in PHP. If I try to echo it out, it's just blank.
PostPosted: Thu Jul 29, 2010 4:46 am
CrashTECH wrote:
Stop using PHP...
Lack of a solid debugger pissed me off. Even Classic ASP had a debugger in Visual Studio 6, yeesh. .NET made my life a lot easier, been using it since. Ruby on Rails is pretty neat too, if you're on OS X you could get AquaMacs (emacs for Mac) and it's pretty robust for Rails dev. I'd code in RoR or .NET anyday.
PostPosted: Thu Jul 29, 2010 7:02 am
Try Greeble.
I personally haven't used it but I then again, I don't use PHP, however I hear this is an extremely powerful codebase to try out.
Quote:
It has many features such as built-in error logging, localization, and easy object-oriented database access.
Could it be what you need?
PostPosted: Thu Jul 29, 2010 11:40 am
Proper unit testing ftw?
PostPosted: Fri Jul 30, 2010 12:08 pm
Unit tests? wtf are those?
btw, if PHP had something like this (maybe it does, I just don't care to follow it) it would help: http://code.google.com/p/moq/
PostPosted: Sat Jul 31, 2010 7:16 pm
meh, even if you could do unit testing on PHP the fact is, no debugger means difficult time tracking bugs.
 Post subject: Re:
PostPosted: Thu Sep 09, 2010 10:22 pm
Team Member Top 100
Team Member Top 100
Have you turned on error reporting in php.ini?
