It is currently Sun Feb 01, 2015 3:15 pm
 Post subject: C++ command line arguments, determine type?
PostPosted: Wed Jul 07, 2010 6:11 pm
Hello,
I'm writing a program that does DES encryption on a file passed in via command line. If the file is a .des (encrypted) file, I need to unencrypt it. If it is a .txt file, I need to encrypt it.
I've looked around but found nothing so I figured the solution was either sort of complicated or really easy and I was just missing it.
Any help is appreciated, so thanks in advance.
PostPosted: Thu Jul 08, 2010 3:52 am
:roll:
You are writing a program that performs encryption and you can't figure this out?
First, figure out command line arguments. http://tinyurl.com/2ccvp46
Then find the needle in the haystack... http://www.cplusplus.com/reference/string/string/find/
I hate to sound condescending, but writing a program that performs encryption might be beyond your abilities at this point.
PostPosted: Thu Jul 08, 2010 9:19 am
Summer school?
PostPosted: Thu Jul 08, 2010 12:37 pm
Uh,
Thanks for the help.
I know how command line arguments work.
The trouble is that the program doesn't know what the text file should be holding, so I need another way to determine the file type.
PostPosted: Thu Jul 08, 2010 12:47 pm
At some point, the program needs to open the file to be able to read it. At this point, the program must know the name of the file. At that point, you can determine what the file contains.
Alternatively, you could easily write some code that reads the first 10 lines of the file and determines whether it is encrypted. That is a messy hack but certainly not difficult.
PostPosted: Thu Jul 08, 2010 4:44 pm
Yes! that's all I need, the name of the file...
PostPosted: Thu Jul 08, 2010 5:22 pm
You get it from the command line argument! If you know how they work, then you don't have a problem.
c:\myappfolder\myapp.exe -f file.txt
The second command line argument, is the file name, you use the function I linked you to to look for either txt or whatever extension you need. This isn't hard I gave you everything you need already.
PostPosted: Thu Jul 08, 2010 6:06 pm
Hilarious thought: what if he isn't opening the file when launching the app but rather from within the app? :lol:
PostPosted: Thu Jul 08, 2010 6:39 pm
Wait... that doesn't make sense...
He still has to know the file name... so either he is getting user input, hard coding it, or using the cli arguments... one way or another he has to know the file name. lol
PostPosted: Thu Jul 08, 2010 9:25 pm
Exactly. :P
Yeah .. that's why I find this kinda funny.
PostPosted: Thu Jul 08, 2010 9:42 pm
set phazers on condescending because I still can't get this.
int main(int argc, char **argv)
//say i want to cout the name of the file, so i put
cout << argv[0];
//right? but nothing shows.
PostPosted: Fri Jul 09, 2010 3:59 am
I admit, it was a little condescending, but I already gave you the answer....
Google: "c++ command line arguments example"
Result #1: http://www.learncpp.com/cpp-tutorial/71 ... arguments/
If you are just running your program, there won't be any arguments, so argv[0] will be empty.
PostPosted: Fri Jul 09, 2010 11:59 am
its cool. I'm not a very good programmer and I know it.
I'll play around with the page at that link.
Thanks for your help.
PostPosted: Fri Jul 09, 2010 12:47 pm
EFFF YES!
I got it!
I knew it would be crazy simple.
thanks for all your help!
PostPosted: Sat Jul 10, 2010 5:55 pm
Bitchin' Fast 3D Z8000*
I know it sound cool to write something like a DES or 3DES program, but maybe you should put your enthusiasm on hold for a bit and write a program that does the classic ciphers like the monoalphabetic substitution cipher, polyalphabetic substitution cipher, Bacon's cipher, block cipher, etc.
Of course, if you this would require a slightly different cli interface. Instead of the filename arg, you'd probably want to do something more like...
myapp -enc -mono -file filename.txt
... OR maybe ...
enc -mono filename.txt
dec -block filename.txt
At least this way, you won't be killing yourself trying to implement an algorithm that appears to be quite a ways beyond your programming experience, and you'll benefit from having to compose all of these pieces together into a program(s). Just a thought.
Of course, the real fun begins when you start writing algorithms to break the classic ciphers. =)
PostPosted: Mon Jul 12, 2010 3:46 am
+1.
Much in favor of you sticking with some simpler programs. Especially since you admitted you aren't very good yet and you had trouble with cli arguments.
Trying a hard program like that to start is a good way to get pissed and quit and give up on a really good skill.
