It is currently Thu May 23, 2013 10:45 am
 Post subject: Compile java to .exe
PostPosted: Sat Apr 10, 2010 6:51 pm
For school project, we are writing a program in Java. However we are writing with Netbeans which uses Java 1.6, but the teacher's computer only has Ready to Program which uses Java 1.4. The compile we write won't compile on the teacher's computer using Ready to Program. Is there a way to compile the Java to a .exe so it can run off of the teacher's computer without any installation?
PostPosted: Sat Apr 10, 2010 8:55 pm
http://en.wikipedia.org/wiki/Java_compiler
Which leads to, GCJ, which you can use on Windows using either Cygwin or MinGW (if you're using Linux then you should already have GCC). There may be other options, but I don't know of them.
But its a lot of work to set up and not really worth it. There is really no good reason to compile Java to native code. My recommendation is to get your teacher to update his/her Java.
PostPosted: Sun Apr 11, 2010 8:34 am
Million Club - 5 Plus*
You might also look into creating a JAR archive with a manifest that sets the main class. The teacher might have the jre installed for the newer version even though the app used to compile is 1.4 based
PostPosted: Tue Apr 13, 2010 12:20 am
Bitchin' Fast 3D Z8000*
How frustrating! Why on earth would your teacher give a Java programming assignment, but only have a 1.4 version of the JRE?! Uh, LAME!
You could always compile down to the older version, but you'll have to forgo using all of the cool stuff in Java 5 and 6. You need to get her to upgrade. The last time I used GCJ -- it reminded me more of a problem than a solution.
