It is currently Mon Jan 26, 2015 8:46 am
 Post subject: C++ .NET your take?
PostPosted: Tue Jan 25, 2005 1:09 pm
I'm working on learning how to use the .Net framework for C++ right now basiclly just for the hell of it while I look for a good book on the MFC. I was just wondering if you guys think the .Net framework applies well to C++. That is should i not bother with the book? I do like the built in string capabilities but otherwise it changes alot like how print lines. ok now im babaling I'll let you guys answer my original question.
PostPosted: Tue Jan 25, 2005 3:25 pm
Team Member Top 100
Team Member Top 100
If you want .NET functionality with C-style syntax, use C#.
That's my take.
PostPosted: Wed Jan 26, 2005 6:22 am
In the lab!
In the lab!
c++.net is the future for programming on windows. While you will always be able to use other c++ tools/compilers if you plan to use Microsoft you might as well just learn it.
It might be handy to familarize yourself with MFC. If you go into a place where you need to manage old code there could be a chance you'll find yourself looking at code using MFC but don't bother really getting into the nitty gritty details.
PostPosted: Wed Jan 26, 2005 1:57 pm
Team Member Top 100
Team Member Top 100
Well, C# has much more hubbub about it than C++ .NET. I'd say C# is really being pushed more than C++ .NET.
I've seen waaay more projects in C# .NET than in C++ .NET. Way more.
And MFC is pretty much dead. It never really got much support from the users because it is a nightmare to use.
EDIT: Damn those typos!
PostPosted: Wed Jan 26, 2005 8:49 pm
Hmm. Thank you for the input. I've been waiting to reply to see what you guys said over a couple replys. I guess I'll continue to learn C++ .NET but also learn C# and C#.NET which I was planning anyway. Again Thank you
PostPosted: Thu Jan 27, 2005 1:31 pm
Hmm im playing with some ideas with Console Applications (.NET) and its not adding the Press any key to continue... its just exiting automaticlly. Any idea how to correct this?
 Post subject: Re: C++ .NET your take?
PostPosted: Thu Jan 27, 2005 4:14 pm
C++.NET is kind of the bridge between old school MFC coding and .NET, but for anything .NET, C# and VB.NET definitely. I wrote code for C++.NET and it was NOT fun at all, C# is a by far easier and cleaner than C++.NET.
PostPosted: Thu Jan 27, 2005 4:32 pm
Team Member Top 100
Team Member Top 100
std::cin.get();
or its equivalent in .NET
PostPosted: Thu Jan 27, 2005 4:49 pm
You can add a console.readline() at the end.
PostPosted: Thu Jan 27, 2005 5:04 pm
thats true but i thought it was suppose to do it automaticlly
