It is currently Tue Apr 28, 2015 5:13 am
 Post subject: Quick Question
PostPosted: Fri Feb 05, 2010 7:38 pm
in C++ how does one write an app that can force commands through the console window?
Like I find myself using certain commands repetitively in dos, and would be nice if I could have an app where you can browse to a file, set that file, then select the command to execute on the file and bam i'm done instead of having to retype the same things every time.
PostPosted: Wed Feb 17, 2010 7:21 pm
Team Member Top 100
Team Member Top 100
Can you give an actual example of what you want?
I'm thinking of system("dir *.*"); type of code, built into a menu system, but using system(), is not a very elegant way to do this.
Give a couple exmples, and I'm sure I can give you something better than just using system().
PostPosted: Thu Feb 18, 2010 4:48 am
This is what batch scripts and powershell is for.....
PostPosted: Thu Feb 18, 2010 9:58 am
Like I have to run a program called tool (it's 100% command line based)
Example of what I type:
cd <directory of Tool>
tool bitmaps <dir>
tool bitmap <dir> filename
tool build-cache-file <dir>
PostPosted: Fri Feb 19, 2010 10:24 am
put that in a batch file, you win.
http://www.google.com/search?q=windows+ ... parameters
PostPosted: Fri Feb 19, 2010 12:01 pm
Ooooh I didn't know I could pass parameters to a batch file.
So, for example/pseudocode
#include <stdlib.h>
#include <necessary stuff>
<get user's desired command>
<get user's desired file path>
system("execTool.bat" + desired_command + desired file_path );
PostPosted: Sat Feb 20, 2010 5:12 pm
Why do you need to use C++ at all? You can have a batch script / powershell script to do everything you need.
PostPosted: Sun Feb 21, 2010 5:09 pm
For a gui.
