It is currently Wed May 22, 2013 5:18 pm
 Post subject: Java Guess My Number Program Help
PostPosted: Sun Nov 22, 2009 10:28 pm
I am working on a program and the goal is this:
Generate a random positive 2 digit number.
Give the user up to five chances to guess the right number. If they are wrong, tell them whether their guess was too high or too low. If they guess correctly, tell them that they won and exit the program.
I know I need to use the random class to generate the number and either JOptionPane or a scanner to get the input. Along with a loop...
Can someone help me with this basic program?
PostPosted: Sun Nov 22, 2009 11:42 pm
We don't do homework here.
If you want help, you need to show what you've done and what you need help with .. simply posting the assignment is not going to get it done.
PostPosted: Tue Dec 15, 2009 8:15 pm
well, I can get your brain working awhile, right?
it's not our job to enforce academic honesty, but we could at least offer some help.
asking the user to guess the number repeatedly should jump out as you as the perfect place for a loop, such as one that iterates 5 times.
inside the loop, you'd want to ask the user for input then decide what to do based on the input. I think you outlined that part pretty well yourself.
and google is very useful for figuring out which java functions to use for simple integer input and random number generation.
PostPosted: Wed Dec 16, 2009 10:36 am
I'm pretty sure the assignment was due over a month ago. ;)
PostPosted: Mon Mar 01, 2010 10:19 pm
Bitchin' Fast 3D Z8000*
In that case... ;)
CL-USER>
(defun number-game (num-guesses)
  (let ((num (+ (random 90) 10)))
    (dotimes (i num-guesses)
      (format t "~%You have ~a chances left to guess the number.~%" (- num-guesses i))
      (format t "Guess? ")
      (setq guess (read))
      (cond ((< guess num)
        (format t "You guessed too low!~%"))
       ((> guess num)
        (format t "You guessed too high!~%"))
       (t
        (format t "You guessed correctly!~%")
        (return t))))))
NUMBER-GAME
CL-USER> (number-game 7)
You have 7 chances left to guess the number.
Guess? 50
You have 6 chances left to guess the number.
Guess? 75
You have 5 chances left to guess the number.
Guess? 67
You have 4 chances left to guess the number.
Guess? 71
You have 3 chances left to guess the number.
Guess? 73
You have 2 chances left to guess the number.
Guess? 74
T
CL-USER>
