It is currently Sat May 25, 2013 9:42 am
 Post subject: no sound!!! where did all the sound go!!! nooooo!!!!
PostPosted: Thu Jul 08, 2004 6:58 am
:x about two months ago we were trying to hook up to the internet. problem was that i was running millenniun edition, yuck!! everything was working fine except we couldn't get on the internet. after about 2 minutes of trying to figure out the problem, my friend told us he could get us xp pro cheap so we did. however, after upgrading to xp pro our sound stopped working. it says something like it needs a sound card to run sound. could someone please help me. i now have thew internet but no sound. :cry: is it to much to ask for both
PostPosted: Thu Jul 08, 2004 8:21 am
Contributing Writer
Contributing Writer
System specs would be helpful, namely the motherboard. It's likely all that's needed is a driver install for your onboard sound (assuming you didn't disable it in the BIOS as well).
PostPosted: Sat Jul 10, 2004 6:52 pm
its possible too that your card is not supported by xp depends what your specks are get us thoes and we might be able to help more
PostPosted: Sat Jul 10, 2004 8:45 pm
or he may just need the Windows XP drivers for the soundcard...
remember Occam's Razor? :)
PostPosted: Sun Jul 11, 2004 8:38 am
it would help alot if you tell us what soundcard do you have? is it onboard or add-on? i think you might just need updated drivers for your soundcard.
Users browsing this forum: B_Nut360, Google Adsense [Bot] and 2 guests
