It is currently Thu May 23, 2013 6:41 am
 Post subject: Dual Layer DVD software ?'s
PostPosted: Sat Jun 26, 2004 6:04 pm
I have Roxio EZCD 6. Does anyone know if it will burn to a dual layer disk. I have the new Liteon SOHW-832S in my hot little hands. I havent installed it though. It comes with Nero express,but I was wondering if the Roxio will work. I got no help from an email to Roxio.
Jim Scarpine
PostPosted: Sun Jun 27, 2004 10:11 pm
Astro lube 2 the MAX!
From a couple DL reviews I have read, usually detects the disk as DL, and should be able to burn without worries. Well the reviews were using Nero. But in your case should work. If not, I bet roxio would come out with a patch that would support the use of the media. As soon as it gets avaliable.
Users browsing this forum: Nastyman and 0 guests
