It is currently Wed May 22, 2013 1:59 am
 Post subject: looking for speakers to go with HT Omega Claro Halo
PostPosted: Sat Oct 27, 2012 6:45 am
I upgraded my sound card to the HT Omega Claro Halo sound card, currently using with the Logitech Z-5500 5.1 surround system. The sound card is awesome with headphones, but I'm not as happy with the speaker sound.
I do some gaming, but mostly I use the speakers for listening to music. I'm interested in getting some good speakers (probably 2 or 2.1) that will work with my sound card and provide excellent sound. Suggestions?
 Post subject: Re: looking for speakers to go with HT Omega Claro Halo
PostPosted: Sun Oct 28, 2012 8:35 am
Funny what a real sound card will do to cheap speakers. If you can find 'em Klipsch Promedia 2.1 or 5.1 are the best bang for the $150 bucks. If you have the wallet you could look into reference speaks like the AudioEngines or Bowers & Wilkins MM-1.
PostPosted: Sun Oct 28, 2012 8:55 am
Here's a thought: why not use an amp that has a digital audio input? This eliminates any concerns about noise generated from the computer affecting the analog output of the sound card. All audio is processed as digital anyway.
I've heard from some folks on a certain image board that the best setup is an amp with passive bookcase speakers. Computer speakers try to do everything and as a result they usually lose the mids.
