It is currently Thu May 23, 2013 3:15 am
 Post subject: Other Media?
PostPosted: Mon May 07, 2012 12:24 pm
I'm wondering if there is other media that is just as good (in your opinion) but not as expensive. memorex seems to be about $1 per disc. anyone have experience with other manufacturers (Ritek, SuperMedia, etc.)? Should I just dish out the mulah? o ya, i'm looking to get dvd-r and will be purchasing maximum pc's recommendation on the px 712a burner. thanks.
 Post subject: Re: Other Media?
PostPosted: Tue May 08, 2012 12:43 pm
Sandisk flash drives are good media, as are the Kingsgate and Corsair ones.
IBM made good Floppy media, as did Sony. A few of those are even still in use in my house.
Any of the big names are good for hard-disk media.
That's all the media I can give a good recommendation on.
PostPosted: Wed May 16, 2012 11:10 am
I think he wants to know about dvd media, considering he mentioned a plextor drive.
we have had good luck with tdk, and memorex, have had no luck with any -r disks, we only use +r disks which seem to work much better. I have an older plextor, a samsung, and a memorex burner, my son has a couple of different burners, but the tdk disks work well in all of them.
It could make a difference depending on what you are going to use them for. data, music, movies.
we buy in bulk 50 or 100 packs to keep the cost down.
PostPosted: Thu May 17, 2012 5:04 pm
<facepalm>
Now I feel stupid...
Yeah, TDK dvds are really good.
PostPosted: Thu May 17, 2012 7:05 pm
CD / DVD media from least coasters to most coasters.
Ritek
Taiyo Yuden
Verbatim
TDK
Imation
Phillips
Memorex
Sony
Maxell
Check out Meritline for great deals
http://www.meritline.com
For what it's worth, I haven't seen any difference between -r & +r media from any of the top 5 in my list.
