It is currently Sun May 19, 2013 12:51 am
 Post subject: Blu-ray player software
PostPosted: Sun Jan 15, 2012 8:17 pm
I just did a Christmas build. (see sig) It has an ASUS blu-ray drive in it. I popped in AVATAR and found out Windows media player doesn't support blu-ray >.< Is there any free blu-ray player software out there that will play a blu-ray disc?
 Post subject: Re: Blu-ray player software
PostPosted: Sun Jan 15, 2012 11:27 pm
Team Member*
Team Member*
Here are the specs from the sig.
Current build:
AMD FX 4 core @3.6Ghz
Nvidia GTX 560 Ti
16GB Ram @ 1666mhz
4TB Storage
PostPosted: Mon Jan 16, 2012 12:36 am
Just to make sure, there wasn't a disc included?
This is the only one I know of http://www.digiarty.com/ however I have not used it.
PostPosted: Mon Jan 16, 2012 5:59 am
I ordered the drive as OEM so no disc :( I tried digiarty and it doesnt work :( Also sorry, I didn't realize my sig wasn't in the original post, I'm a n00b still :)
PostPosted: Mon Jan 16, 2012 6:00 am
Team Member*
Team Member*
Have you tried Power DVD or Cyber link?
PostPosted: Mon Jan 16, 2012 8:20 am
yeah but you have to pay for it :(
PostPosted: Mon Jan 16, 2012 1:15 pm
Team Dino
Team Dino
VLC is free, but I'm not sure if you'll need the AACS keys.
n0b0dykn0ws
PostPosted: Mon Jan 16, 2012 2:50 pm
I purchased a Samsung OEM Blu-ray drive and it came w/ Cyberlink 9 OEM. Also your signature is on your profile, you didn't post it.
PostPosted: Tue Jan 17, 2012 1:49 am
Team Member*
Team Member*
You should be able to DL a OEM or light version of Cyberlink Power DVD from the Asus site. just find your model number and go to [url]http//:www.asus.com[/url] look up your drive and go to the download section tab. I'm not sure what options you will have from there but, you should be able to pick up a copy from there or call them up and let them know what you have and a invoice number. They should be able to set you up with something.
PostPosted: Wed Jan 18, 2012 5:24 pm
Million Club - 5 Plus
theres also a free workaround way to do it. its a pain though.
VLC will play the m2ts file but not from the disc directly. rip the bluray with DVDFab 8 QT (free), that will decrypt and rip it to your HD. then use VLC.
