It is currently Wed May 22, 2013 4:15 am
 Post subject: Correct my video's aspect ratio?
PostPosted: Wed Apr 06, 2011 5:22 pm
I shot some footage using a Contour HD helmet cam. The resolution is 1280 x 960 and things look tall and skinny.
To correct the squished view, what resolution and aspect ratio should I use when I re-encode the video?
I've tried selecting 4:3, 16:9, and 16:10 but my eyes are playing tricks on me ...
 Post subject: Re: Correct my video's aspect ratio?
PostPosted: Thu Apr 07, 2011 12:34 pm
Could try 1280 x 1024? could make it more square also with 1024x768, or an up convert to higher resolution.
PostPosted: Sun Apr 10, 2011 7:44 pm
Location: Playing Chicken with the Train at the River. Party Time!!
Knowing what OS and rendering software you are using would be most helpful to those of us curious and wanting to help! :)
Edit: I found the software: http://contour.com/software/storyteller
Unfortunately, I'm unable to help. :(
