It is currently Sun May 26, 2013 12:22 am
 Post subject: Tv on the pc
PostPosted: Mon Feb 21, 2011 8:47 am
Hey guys how do you get TV on your PC?? I have cable internet is there some hardware u need?? Have no clue what it takes to get tv running thru the pc thanks for the help
 Post subject: Re: Tv on the pc
PostPosted: Mon Feb 21, 2011 9:12 am
For hardware you'll need a TV-Tuner card such as the Hauppauge WinTV-HVR-2250.
Software wise Windows Media Center is installed already if you have Windows Home Premium or higher.
PostPosted: Tue Feb 22, 2011 7:37 am
Team Dino
Team Dino
If you have a number of digital channels, or you only receive digital through your cable provider, you will need a CableCard tuner, such as the one from Ceton.
If you want analog and digital, unfortunately you'll need two cards.
I have two of the HVR-2250s and it's rock solid. A little slow on channel locking, but otherwise a great card.
n0b0dykn0ws
