It is currently Sat Apr 25, 2015 3:46 am
 Post subject: Bah humbug...
PostPosted: Sun Jan 04, 2009 6:19 pm
My Gigabyte GA-M57-SLI-S4 just died.(I can smell this disgusting smell coming off the board when I opened my case.) Thankfully,I just ordered a new motherboard.My new motherboard is a Gigabyte GA-MA790GP-DS4H. Cost me $138.99 with $9.39 3 day UPS shipping,but I wanted guaranteed support for my Phenom 9950BE.
God this sucks...
Just goes to show you can't trust everything you see. I bought my GA-M57-SLI-S4 hoping it would support my Phenom 9950BE. Apparently,the 125-watt 9950BE was too much for the board to handle.
Thank god for having a backup Linux PC to use.
 Post subject: Re: Bah humbug...
PostPosted: Sun Jan 04, 2009 6:48 pm
Million Club
Million Club
Looking at this http://www.gigabyte.com.tw/Support/Moth ... uctID=2287
What is the difference between your CPU and the 9850, I'm not familiar with AMD but if the MOBO supports 125 watt CPU's then what went wrong?
Edit
Which revision do you have?
PostPosted: Sun Jan 04, 2009 7:06 pm
The revision I had was rev 2.0.
PostPosted: Sun Jan 04, 2009 9:02 pm
Edit
My understanding is that sometimes motherboard manufacturers claim that boards support certain High wattage CPU's just because it will post and enter the OS on the board , without the boards Chipset and/OR VRM (Voltage Regulator Module) really be able to handle the load for the long term and then after a certain amount of time it can fry the board. For example AMD's website states that the AMD 770 chipset does not properly support greater than 95 watt processors but many boards with that chipset are stated as being supported. I don't know how accurate it is but AMD's site lists the 790FX and 790GX as the only properly supported chipsets.
http://products.amd.com/en-us/RecommendedMBFilter.aspx
PostPosted: Sun Jan 04, 2009 9:04 pm
Monkey Fed [PC]
Monkey Fed [PC]
Keep in mind that it's not just the chipset that will determine support. In this case, it actually may be the quality of the mobo and the traces supplying power to the CPU, not to mention the voltage regulators/IC's.
 Post subject: Joy oh Joy...
PostPosted: Sun Jan 11, 2009 6:10 pm
My new motherboard(Gigabyte GA-MA790GP-DS4H) is installed and working. I had to do a fresh install of Windows Vista Ultimate,but now it's working fine. (Now the tedious part- re-installing all my games and add ons.)
I sure love Gigabyte....
