It is currently Mon Jan 26, 2015 6:11 pm
 Post subject: grrr Vista
PostPosted: Sat Nov 08, 2008 6:00 pm
I hate vista now after having it for months now.
I brought a Dell M1530 fully loaded with a Intel Duo Core 2.0Ghz, 4gb ram, 320 gig hard drive, and Nvidia 8600gt, but the one thing i was worried about was Vista. Vista was actually alright at first but then i started having problems with some of my games like NFS Carbon (it should work but it doesn't , and some programs like divx don't work properly. I'm just gonna start over with Vista afresh and then see if everything is fine, if it doesn't i'm just calling it a day, and i'm just gonna have to sit with it
until windows 7 comes out. i can't install XP either which sucks so i'm stuck.
PostPosted: Sat Nov 08, 2008 6:14 pm
Million Club 2+ [PC]*
Make sure you've updated to SP1 for Vista. I use Divx on my Vista 64 install with no issues.
PostPosted: Sun Nov 09, 2008 8:37 am
It is SP1 but i still get numerous problems so now i think i should reinstall Vista and start over.
PostPosted: Sun Nov 09, 2008 9:58 am
Million Club [PC]*
Million Club [PC]*
Are you using Divx (the official codecs, I'd guess?) for encoding work, or just for playback?
If the latter, I'd suggest uninstalling the Divx bundle, and installing ffdshow-tryouts. Myself (as well as many other people - take a look around at thegreenbutton) have had, well, issues with the official Divx codecs under Vista, especially within Media Center.
ffdshow is a lot lighter, and quite a bit faster. My lappy struggled a bit with avi playback with the 'real' codecs installed; no problems with ffdshow.
PostPosted: Sun Nov 09, 2008 10:33 am
Monkey Fed [PC]
Monkey Fed [PC]
Yes, DivX on Vista is really sucky. Get the FFDshow and kiss your problems goodbye!! Although, I'm beginning to suspect that FFDShow MAY be the cause of some of my Fallout 3 errors, but I'm not sure yet.
PostPosted: Tue Nov 11, 2008 3:49 pm
And for Need for Speed Carbon, set the compatibility mode to Windows 2000 (Not XP, not 95, but 2000 ;)). I have no idea why, but that's what did it for me.
-Budgetperson
PostPosted: Sat Nov 15, 2008 11:16 am
Ok instead i used the dell factory image reset. (i was too lazy to reinstall vista)
But the image worked fine, i had to install my programs, and change my settings but it was worth it, Carbon Worked, and so far i haven't had problems. I already beat the games and hadn't had a problem.
Divx works alright, but i haven't installed winamp yet. i had a problem with Divx in winamp mainly.
So maybe vista isn't that bad as i thought, but i guess i should just wait for the updates, and maybe it will fix the problems.
PostPosted: Sun Nov 16, 2008 3:14 am
Using vista on my dell Xps M1530 laptop, no issue. just update till its done.
PostPosted: Mon Nov 17, 2008 4:35 pm
Vista is Been Running fine for a week but Divx is really being a bitch! :evil:
I use Divx for my videos i download off of youtube. Do you guys think i should try a different format like Mpeg 2 or Windows media, I'm really considering this now...
I also noticed my Xvid videos don't work in Media Direct.
PostPosted: Mon Nov 17, 2008 4:50 pm
Monkey Fed [PC]
Monkey Fed [PC]
Try FFDShow....really. Most, if not all, of your problems will be history.
PostPosted: Tue Nov 18, 2008 1:20 pm
ok i'll give FFD a try and if it does not work out for me then i'll switch to a different format.
PostPosted: Tue Nov 18, 2008 5:08 pm
it doesn't seem to be working, so i think i'll just switch to a diffrent format.
Any suggestions? Also which codec should i use?
