It is currently Sun Apr 26, 2015 3:01 am
 Post subject: Did this cat change its spots or stripes
PostPosted: Fri Oct 08, 2004 10:24 am
http://www.eanthology.com
Just wanted the dog pound check into them .... they are the makers of Stop Sign (eacceleration) .... I have read in several searches that this company automatically charges your Credit Card every month after you purchase the software...supposely its all in one software..firewall,anti virus ,anti spyware,anti spam,pop up killer...down below is an email one of their support members sent me after I talked to them on the phone. My main concern about their software was that almost all the Anti Spyware Programs I have installed called this software(eacceleration) Spyware. Spybot S&D ,Ad Aware SE, Spysweeper, XCleaner just to name a few called it Spyware
Quote:
Hello Tom,
I do apologize for any inconvenience.
Often times, this sort of challenge can be caused by having multiple
security programs installed on the same machine.
It is strongly suggested to uninstall all other security programs and
reinstall Stop-Sign to make sure that none of it's files have been
deleted, damaged or corrupted in any way to ensure that you are
being protected to the fullest extent.
Below, I have included some steps for this, should you require them.
One way you can tell if you have any other security software installed on your machine is to follow the steps below.
NOTE: please take caution in choosing what programs you decide to remove from your computer, as removing any vital programs may cause challenges with the performance of your machine.
If you are unsure as to weather or not a program should be removed, it is suggested to leave it alone for the time being until you can ask someone who knows what can and can not be removed safely. (for example: your tech support company.)
Let me know what the Dog thinks!
PostPosted: Fri Oct 08, 2004 8:32 pm
I looked into them recently, they constantly run an comercial on the A&E channel...they don't look good from what I've read
PostPosted: Sat Oct 09, 2004 8:42 am
If some software company is telling you that they, and only THEY are allowed to have software on your machine, dump their product in the nearest 'nuke'em' bin. Nobody has a right to tell you what software may or may not reside on your system.
PostPosted: Sat Oct 09, 2004 2:00 pm
Smithfield*
Smithfield*
thats commercial is such annoying shit. 2 foreigners all serious with shitty graphics done in the 90's with compuers running around infected then scanned. ugh.
