It is currently Sat Mar 28, 2015 3:25 am
 Post subject: Stupid Microsoft
PostPosted: Fri Mar 11, 2005 5:43 pm
I see a notification in my system tray that Microsoft has an update for my ethernet adapter. So I click OK to download it. And the first thing the installer does is disable my ethernet adapter so Microsoft can update it. DOH! That annoying little icon has been sitting un my tray for two days. Tommorow I will have to manually download the upgrade and install it to get rid of the icon.
PostPosted: Sat Mar 12, 2005 3:09 am
Folding Momerator
Folding Momerator
Why not uncheck it to get rid of it? If you uncheck it, download turns to close, you will then get a notice not to remind you about this download again.
PostPosted: Sun Mar 13, 2005 5:57 pm
"Please try the following:
Click the Refresh button, or smash your computer with a large hammer.
If you typed the page address in the Address bar, make sure that it is spelled correctly, you stupid idiotic moron.
To check your connection settings, open case with a screw driver then, fill with gasoline. Now take a match and proceed to ignite. The settings should match those provided by your local crazy arsonist (LCA) administrator and Internet service provider (ISP).
your Network Administrator is an idiot, Microsoft Windows can examine your network and automatically screw everything up.
If you would like Windows to screw everything up,
click Screw everything up
Some sites require Windows to suck more than normal. Click the Windows menu and then click Windows suck rate to determine what strength "Suck" you have installed.
If you are trying to reach a secure site, make sure you are not running Windows. Click the My Computer menu, and then right click Drive C:. On the Menu select "Format".
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Exploder "
Quoted from http://www.thispagecannotbedisplayed.com/
