It is currently Sun Jan 25, 2015 8:44 pm
 Post subject: http://www.openoffice.us.com/
PostPosted: Wed Jan 19, 2011 11:40 am
Is this legit ? I just downloaded open office from them and there is a new toolbar on my computer but not open office. Are these people trying to give me a virus or what ?
 Post subject: Re: http://www.openoffice.us.com/
PostPosted: Wed Jan 19, 2011 12:23 pm
was the toolbar an optional part of the install? toolbars can usually be uninstalled and removed, and sometimes during the install you can choose not to install them...
i think the main OpenOffice website is http://www.openoffice.org/
PostPosted: Sat Jan 22, 2011 7:54 pm
from the bottom of their main page in tiny print.
"OpenOffice is developed and maintained by Oracle and it’s affiliates. OpenOffice.us.com is not directly affiliated with Oracle or Sun Microsystems."
PostPosted: Mon Jan 24, 2011 2:33 pm
Million Club - 20 Plus
That is definitely not the main website.
Ted
PostPosted: Sun Feb 06, 2011 3:43 pm
You can get OpenOffice from openoffice.org without all the extra crap. Plus, that's the official site. Obviously it's not legit, because I've used OpenOffice on many installs, but only would download it from the actual website.
I would suggest doing a roll back on your system (if you can--just in case it installed any malware or spyware), and download a new copy from OpenOffice.org (that is the legit real website).
Oh, and I always do a custom install (on all the apps I install) just to make sure there is no toolbar or other stuff I don't want. For example, FoxIt Reader tries to install it's toolbar, which I never do when I install it, but you have to be careful during installs to install only what you want, because a lot of free apps these days try to install toolbars and freeware stuff that you probably don't need or want.
PostPosted: Sun Feb 06, 2011 8:39 pm
^^^ What he said
If you opt for a standard install the toolbar is installed with OO. Choose a custom install and uncheck the toolbar installation selection. It defaults to install which sucks. Never allow a standard install for any program. They get paid tons of money to sneak in a these stupid toolbar installations. That being said, if they get one past you you can disable it in Firefox by right clicking the menu bar and unchecking it, which will disable it but not uninstall it, or open control panel and uninstall it.
Never, never, never allow a standard install if a custom install is offered and then pay attention to any check boxes they try to slide past you.
PostPosted: Mon Sep 29, 2014 3:29 am
To find a site is legit or not, you can do some methods. You can check whois lookup for a domain name. Visit the site WhoisXY.com here you can check whois information for domain name. If the information is public and looks legit,you can note the email id, contact number of the domain name owner or administrative or technical department or else sale department. It will help you to contact them if you have any problem after using their services or buying their products. Then you can visit the site ScamAdviser.com check whether the site is trusted or not. If the result will "High Trust Rating. This Site Looks Safe To use." It is good site. Then you can visit Webutation.info here you can read users or customers reviews, ratings and feed backs about the site and their services. If they said good, you can start using the site.
