It is currently Mon Mar 30, 2015 3:38 pm
 Post subject: Quadro vs. GeForce 6XXX comparison?
PostPosted: Wed Dec 22, 2004 1:11 pm
Team Member Top 100
Team Member Top 100
After an exchange in the Hardware Haven (linky-linky) about possibly using a Quadro board in a gaming machine, I started wondering if the guys in the lab would do a vid card comparison between GeForce 6XXX boards and the latest Quadro boards.
Looking at the hardware specs between the 6600 & the QuadroFX 3400 yields a roughly equivalent set of specs--would they run Doom 3 or HL2 with roughly equal aplomb? What about a top-of-the-line Quadro board?
I did a quickie search on Google, but it turned up only 1 relevant hit--a discussion thread with no benchmarks.
Just wondering.
PostPosted: Sun Dec 26, 2004 7:13 am
Maximum PC Editor
Maximum PC Editor
The modern workstation boards aren't suitable for gaming. When you try to run a game like Half-Life 2 on them, things just don't work right. For example, the Quadro FX 4000 that we used for the Apple Cinema Display test just wouldn't render water at all. I didn't have time to figure out why it did this though.
You're better off buying a gaming card if you want the fastest, best looking gaming images.
///Will
PostPosted: Sun Dec 26, 2004 8:37 am
Celeron
Celeron
///Will
*Psst* Hey Will, did you get to see this thread? The FX's don't render the water correctly at all. Sorry for making you C&P this :wink:
PostPosted: Mon Dec 27, 2004 11:04 am
How was that 30" LCD? Is it t3h best?
PostPosted: Tue Dec 28, 2004 8:50 am
Team Member Top 100
Team Member Top 100
Thanks, Will
Hearing the experience of someone who has actually had these cards on the bench is very helpful.
As I mentioned, their raw performance numbers appear similar.
Thanks for the input.
